Rolla Help Club ?
Fook, on your car we could do a head replacement in under 2 hours, all things going well. The quickest I've seen a head off and on on a K motor was 45 minutes. Timing chain could take a bit longer, but is also achievable.... anything is possible! :blinks:
R
  • Replies 70
  • Views 35.4k
Rob: That quick? Wow... I would assume that would be with a replacement head (and not taking the head off and fixing it up and putting it back on)? Well Jamie recons if I'm going to take the head off and do the timing chain I might as well also spend an extra $100 or so on a cam grind (but that would mean having the car off the road for a bit). Maybe after I get the 35 running - so I have another drive car - I'll fix it all up :blinks: Or maybe I'll do it now... Anyone have a spare cam? :)
If we're fair dinkum it's a day job for everything. And that's with change over head. (Of which I have a number of spares...) I think I have a number of camshafts around, too.
No, you can't have my Wade 169x cam. :nono:
R
Oh wow, hehe maybe after a days work Pinky will go so well that I'll forget about even the KE35! :blinks:
I've never heard of a timing chain letting go in a K motor either (have heard of timing belts letting go in other engines, some with rather disastrous results), but I'm guessing all that rattling and stuff can't be good... Who knows, maybe my tensioner's just worn or something.
How does one "fix" problems with a valve stem seal? Replace the valve? Rehone the valve seats?
I agree with doing belts every 100000k, but timing chains on K motors don't generally give trouble. If it's giving a problem (noisy), no worries, whip it out and change it, but changing it for change's sake is not worth it. Unlike a belt, chains are really "talkative" and will let you know when they flog out. They give you a lot of warning. I'm only trying to save people from work. :blinks:
Valve stem seals: they're a little rubber seal that prevents oil from flowing down from the top of the head, down your valve stems, and, therefore out your exhaust. To replace them means removal of valve springs, and, to be honest, if you're going that far, you may as well do the whole head. I have a guy in Redcliffe who does all my heads.
R
how much could hey do mine for ?
Tom
:blinks:
ok whos got a MIG welder (arc too possibly...but might not work)
need to weld up some holes in my muffler...muffler putty just aint cutting it
would like to put a TIP on there too. Theres a carton of beer in it for ya :blinks:
hehehe...can't be any worse than my attempts at arc welding...damn that shit aint easy
*curses rods getting stuck to work surfaces*
can't really make the muffler any worse than it is...I have a GTi Swift muffler here I can replace it with anyway...just the power loss it would bring isnt something I'm looking forward to :dry: rather keep that for when the AE86 comes
Okay cools. So is the muffler still on the car? or... Just cause well, welding upside down is even harder than welding the right way around... I don't know if I can bring the welder to Robs place tho, just cus the gas bottle doesn't quite fit in Pinky...
