October 17, 200719 yr comment_203861 Hey, Soon i will be looking out for a few more cheap rims to have thrash tyres on, and was wondering (to help out my search, and help know what else i can look for at the wreckers), what other cars share the same stud pattern and wheel/rim diameter, with a fairly similar width of rim + tyre, as the Ke's. Are there other jap cars with similar specs ? Dattys or old Gallants or something ? Your help is much apreciated ( i hope this has not been asked a million times before, making me look even more stupid :lolcry: ) Cheers Report
October 17, 200719 yr comment_203864 Rwd Celica's. Rwd late 70's and 80's model Corona's. 70's model lancers Sigma's I guess Galants as well. Starion's fit. Report
October 17, 200719 yr Author comment_203888 Rwd Celica's.Rwd late 70's and 80's model Corona's. 70's model lancers Sigma's I guess Galants as well. Starion's fit. Thanks man, That helps a lot, i did'nt realise there would be so much choice! Report
October 17, 200719 yr comment_203959 depends which KE you have , KE1# throung to KE2# have 4 x 110 stud pattern which is only common with old mazda ( rotaries and early ones ) the KE3# onwards have 4 x 114.3 which have much more available car wheel stud pattern chart Report
October 18, 200719 yr comment_204056 lindsay is correct. my ke20 has a set of simmons which came off of an rx4. the mazda's ran 4x110 untill the series 3 rx7. apart from the commercial vehicles the rest were the same. Report
October 18, 200719 yr Author comment_204129 thanks all, I am intending to pick up a ke15, 20 or 25, but it is still useful to know what i can use I will look around for some rx4 rims Are there any 'stockies' that will fit? Report
October 18, 200719 yr comment_204131 Every car i mentioned has a different stud pattern to a ke15/20/25. Rwd 323's S1 S2 S3 rx7's Rx4/3/2 R100 Report
November 26, 200718 yr comment_211477 Rad Rolla, if it is for a ke1x or ke2x, look for RWD mazda 626 rims. They are 13x5.5" and are way easier to come by than the rx4 rims. Report
November 26, 200718 yr comment_211482 Rwd 323 are reasonably common in wreckers and have 13x5 or 5.5 rims too. Report
November 26, 200718 yr comment_211485 I had some rwd 323 rims on my ke15 at one stage, the ones I had were 4.5" wide. Report
November 27, 200718 yr comment_211760 geminis fwd celicas and corollas Useless, useless post. FWD Celicas have either the 5x100 (SX ST162s and every other one since) or 4x100 stud pattern (ST model ST162). Neither of those will fit a KE FWD Corollas have 4x100 PCD, or 5x114.3 on the very new ones, also neither of which will fit a KE Report
