Ke70 Panelvan
  • Replies 47
  • Views 68.9k
  • That is SO hot right now :)
  • Update pics... A mate popped over to check out the Sprinter, ended up staying and giving me a hand to polish the van up, still gotta do the roof. Cheers to Ben for the help, some pics of his car too..
Not sure about the mx62's but there is shite loads of pad options for the rx7 callipers including every heat range of ebc's
Yeah that's one of a few reasons I'm keen on the RX-7 calipers, but I still need to work out the logistics of mounting them up on XT130 struts with MA61 rotors. I have EBC reds on my MR2 and they are really good thus far! :)
Looking good Paul!
Are there many aftermarket sport pads available for MX62 calipers? What is the distance between mounting bolts on the caliper?
I'm looking at running a similar setup but am worried about my pad options. The other thing I am pursuing is 4-pot RX-7 calipers with the above
rotors and struts...
Cheers,
Dougal
Whatever pads you can get for RA60/MA61 should work in the Cressida caliper too from what I understand, I'm running the ferodo pads that were in the calipers when I pulled them off the Cressy at pick-a-part and they're fine so far. RX7 calipers would be overkill I recon, and will not work with MA61 rotors as the FC runs 22mm thickness, MA61 is 18mm I think. Mounting bolts are around the 89mm mark off the top of my head. If they're for the KE20 the MX62/MA61/XT130 upgrade will be plenty.
