sorry but i doubt those mini cooper disc setups will be avaliable anytime in the next few years.
ill second that, he is only registering interest, so at the usual ajps way maybe looking at Chrismas next year getting them made lol.
I wouldnt use VT calipers...you need a massive master cylinder to fill them with fluid!
Id suggest RX7 or VB-VS Commodore calipers and Mini discs. These discs only need drilling to 4x100 and a bit chamfered of the hole and they bolt on.
i'm running the hoppers stoppers AUIII pbr twin piston 285mm rotor kit on my ke20b. only needs a 1inch master cylinder which they supplied to suit. fairly massive brakes no strut change came with all the gear ie hubs brackets so on. brakes are one thing you should never skimp on. i'd prefer my last thoughts not to be "i wish i had gone twin pistons" lol. spend he money you'll never regret it.
Edited by YKE 20T
Don't skimp on the brake pads either. Calipers are gonna be useless if you fill them with crap pads. (And no, bendix is not a good quality brand of brake pad)
Ok. VT calipers flex under hard braking thats the main reason why some companies use AU ones. Ring John at Cebco brakes or Matt at Race Brakes Sydney and they will tell you.
Going from a 19.05mm master cylinder to 1" would probably be ok as its a big jump up in size but there are still better calipers about.
