February 5, 200818 yr comment_225554 g'day all, just wondering if any one has any pictures of a t motor in a ke1*, I'm doing this conversion soon and need to know what i have to modify and things like that, i have done a 2tc into a ke55 and it was a breeze, i understand that a ke11 will be allot harder but it has been done, but unfortunately there isn't much floating around that i could find with the search function. before you flame me, i would rather go 4age but they are just to hard to come buy and i have all the t motor parts here to do the conversion. this car will have upgraded brakes and axles so as i can have it engineered and registered. all and any help will be greatly appreciated, thanks casey Report
February 5, 200818 yr comment_225565 as far as mounting the engine, would it just be a case of using the same t motor to k cross member setup as your 55!? Report
February 5, 200818 yr Author comment_225577 i think ke11 k engine mounts are different to ke55 k one. thats what i need to know Report
February 5, 200818 yr comment_225586 actually come to think of it, I tried putting 3k engine mounts on a 4k and they would fit, so yes you're right. You can have the old 3k mounts FOC if they're any help to you! ;) Report
February 5, 200818 yr comment_225608 if you use a KE30 or later exhaust side engine mount it will stand a K motor up in a KE1X as they are a bit bigger. So yes old school KE mounts different don't GO 4age.lol Cameron Edited February 10, 200818 yr by camerondownunder88 Report
February 10, 200818 yr comment_226685 if you use a KE40 or later exhaust side engine mount it will stand a K motor up in a KE1X as they are a bit bigger. So yes old school KE mounts different don't GO 4age.lol Cameron i have always wondered this too.. wether id be able to get a 18RG / 2T or 3T into the ke11 with carb set-up of efi.. anybody know if this has been done before ? Report
February 12, 200818 yr comment_227202 I'm running a 3tc+t50 in my LHD KE17. You will have to cut a new hole for the shifter as well as relocate the transmission crossmember back about 4.5". The tunnel had to be beaten a bit to fit to fit the tranny I used the whole front suspension/steering gear and rear end from a te21, which increased my track by about 1" (also givign me 4x114.3 bolt pattern and the option of ae86 brakes), and put the motor in exactly the right place. I guess t-series cars are quite rare in Aus so you might be better off welding your own mounts together on a k crossmember. With the wider track I could still fit a 13x6 with +25 offset with the fender beads rolled. On a RHD drive car you might have issues with the brake booster if you want to run sidedraughts, I get off easy with LHD! For a rad I used a te21 unit which might be the same as a KE20. To clear the rad you need a short nose water pump and a thin metal fan bolted onto that, theres no room for electric. Battery relocated to the boot. It's a tight fit but it looks like it was made to be there. I love the 2t/3t, they put out tons of torque compared to k or a series motors, and they are really robust. My car is a little more front heavy now but the torque makes up for it, its like driving a muscle car. Theres no way you're going to fit an R series motor in there, it would stick out past the hood lol plus its way too heavy. Might as well put a v6 in it. Report
