February 27, 200818 yr comment_230200 HI all, i have done search for result on this question but no luck. I have come to stage where i am looking for wheels for my ke20, but I'm struggling. I want to run 15's, well thats the smallest i can run due to brakes, and i would like to run 15's. Also my 20 has 4/114.3 stud pattern. so i would like 15inch wheels with a 4/114.3 stud pattern with an offset to clear my struts (stock). NO SPACERS thanks Any help would be awesome or if any one knows any one selling any pm or email me :P cheers pete ps. perhaps a FAQ should be made about what wheel fit and what not. Report
February 27, 200818 yr comment_230222 you can get superlites (similar to watanabe) made up in any size and offset. Report
February 28, 200818 yr comment_230450 Mate i reckon MA61 supra rims would look tops on an KE20 15" , 4 x 114.3 , they tend to pop up on toymods a bit and normally under $500 Report
February 28, 200818 yr Author comment_230506 Yeh they wouldnt look too bad, depends on the offset and what not. From what i have found i need a 15x6 4/114.3 with 20p offset. Only wheel i can find in this is a superlite and that a 6 week wait. Does anyone know if ill get a 15x6.5 4/114.3 with 07p offset in there or will that scrub the guards? 15x6.5 seems a little easier to find and more styles Report
March 9, 200818 yr comment_232262 ^ hey LINDSAY i think you may find those are mz10 rims : 15x6 114.3x4 pcd +20 offset 60mm spigot ma61 rims : 14x7 114.3x4pcd +8 offset 60mm spigot Report
March 13, 200818 yr comment_233163 A lot of 15's will fit. A word of advice, DON'T get coilovers. I learnt out the hard way after spending huge coin on rims and coilovers to find that the rims did not fit anymore because the tyre hit the spring platform. Nothing a 165/50/15 on a 15x7 didn't fix :y: :hmm: :jamie: Report
March 14, 200818 yr Author comment_233247 A lot of 15's will fit. A word of advice, DON'T get coilovers. I have got some superlites coming for it, they are 15x6 with a 24p offset. Where did you get your coil overs from?? Report
March 15, 200818 yr comment_233346 I have got some superlites coming for it, they are 15x6 with a 24p offset. Where did you get your coil overs from?? Nice choice, i've had various 15x6.5 and 15x7's on my ke26 with a range of offsets and have all been good. Only problem i've ever run into was needing longer studs for some. I got them made here in NZ by a suspension specialist, gave them my original hub and supplied new shocks and my choice of spring. Report
