styler Posted April 30, 2008 Report Posted April 30, 2008 seems like ke20, 25, 30, 55 front damper inserts (shock absorbers) are the same fit? if this is the case it would make it much easier to track down absolete listings like ke20 and use listings still avaliable like ke55. pedders monroe rear dampers are different types but usually much easier to find than the front inserts. Quote
Raven Posted April 30, 2008 Report Posted April 30, 2008 (edited) I'm eventually going RA60 Celica front struts converted to coil-overs :rocknroll: Edited April 30, 2008 by Raven Quote
Jono Posted April 30, 2008 Report Posted April 30, 2008 "wholesale suspension" in sydney have been using a KONI shock in ke20s (front) a lot. not sure of the part number but they are adjustable ones. Quote
LINDSAY Posted May 1, 2008 Report Posted May 1, 2008 yeah i got some koni yellows in mine , but needed spacers put into struts for them to fit , not sure of part number but i have it at home Quote
toyocharged Posted May 1, 2008 Report Posted May 1, 2008 Ive got Koni AW11 MR2 rear inserts in the front of mine(modified strut though) and Fiat 124 model konis in the rear. They seem to work well and are good value. Quote
styler Posted May 1, 2008 Author Report Posted May 1, 2008 ah sweet seems there are a few options then, anyone have part numbers + prices? Quote
