Its pretty easy. Weld on a clutch pedal and drill a hole. Get a master cylinder and that should be about it. In a KE55 you would want a mid-mounted shifter point gearbox from a TA22 if possible :D
  • 2 months later...
hey i had a look at converting my clutch to hydrolic in my ke55 and the whole that is in the firewall is offset by bout 15mm or so i noticed urs was
pretty much dead inline. is there a reason there is a difference? johnnyt
Edited by johnny t
Because he cut off the pedal assembly, moved it upwards and packed it outwards. Then welded it back on...as well as extending the clutch pedal.
Do a search for a topic started by me, regarding KE30 KE55 Hydraulic Clutch Setups. I used a different method which hopefully will work just as well.
Edited by kangaroosa
