January 1, 200917 yr Author comment_303337 I work as an Automotive Parts Interpreter, so I'll have a suss with a kit, though I have changed it over and it does have a known working M/C in it. Report
January 2, 200917 yr Author comment_303504 Another update. Took the car into a mechanic today to check over the brakes and it has now been discovered that the master cylinder has an internal leak, sucking in a small amount of air. So on Monday, I'll be getting myself a new master cylinder, bench bleeding it, and then fitting it up after work at some point. Report
January 2, 200917 yr comment_303550 yay :yes: knew it was the master :jamie: whats a new master gonna cost? round the 150 mark? Report
January 2, 200917 yr Author comment_303604 Because I get trade price for most things that are outside of work, its costing me a mere $95 :yes: Report
January 2, 200917 yr comment_303630 can i ask who through? i suspect mine may be doing the same thing. real spongy only just recently, but not leaking fluid. cheers, dave Report
January 2, 200917 yr Author comment_303650 Through a company in Adelaide called ATAP - Click Here If you go to the contact us section, it lists an ATAP in Melbourne :yes: Edited January 2, 200917 yr by Raven Report
January 5, 200917 yr Author comment_304484 So, the saga continues.... ATAP sent me out a master cylinder only to find, when I took it out of the box, that it was a single circuit, not a dual circuit, so I promptly returned it. Now I have to get the master cylinder reconditioned, which is going to cost me $166 all up. Should have that done hopefully by this Friday. Report
January 5, 200917 yr comment_304514 can't they supply you with the correct item? although that said, resleeving is actually better, it lasts for longer... Report
January 5, 200917 yr Author comment_304515 Unfortunately they only do an aftermarket single circuit master cylinder, and its no use to me as its completely different. with only one brake line connection to the master cylinder, not the two each side that I need. Edited January 5, 200917 yr by Raven Report
January 5, 200917 yr comment_304578 Unfortunately they only do an aftermarket single circuit master cylinder, and its no use to me as its completely different. with only one brake line connection to the master cylinder, not the two each side that I need. Why don't you give yours a light hone and fit a $20 seal kit yourself. Report
January 7, 200917 yr Author comment_305287 Took it in today to be reconditioned and sleeved. :y: Should get it back tomorrow or Friday :y: Report
January 8, 200917 yr Author comment_305614 I received my master cylinder today and it only cost me $83 to get reconditioned due to the fact that it had been resleeved before. So if this doesnt work, I'll start clamping brake lines and find out which end or corner its leaking from. Report
January 9, 200917 yr Author comment_306287 Well, the brakes are better but I still lose the pedal on first pump and this was after the master cylinder was reconditioned and bench bled. Next up, I'll be swapping over the front calipers from the yellow project KE25 and see if that fixes it as everything else has been changed. Report
January 10, 200917 yr comment_306301 clamp a;ll the lines and undo one by one, see what helps :( Report
