Well my clutch has been playing up for a while, and last night I couldn't select reverse....and I forgot about the severity of the problem this morning...couldn't select reverse...
turned the car off, gear selection is fine with and without clutch.... put it into reverse, start car, reverse works! YAY.... but then I couldn't get it out of reverse...turn car off... select first, start car, drive off YAY.... oh wait.... can't get it out of first! you see where I'm going with this??!
Thought it could be the hydraulics, but the reservoirs were both full....so I called the RAA to see if they could pin-point the exact problem.... and OMFG! you know what the guy said??!?!!? first off... that's a pretty colour on that car ......then his diagnosis? "Sweetheart! you're just not pressing the clutch pedal all the way in, and it's not engaging. You really need to drive it rough" I couldn't be bothered arguing with him, so I smiled, said "thank you, where do I sign?"
what a frickin DUMB ASS!
I took it to my mechanic and he's said that there is a knob (or raised bit) between where the clutch plate and the pressure plate has come off and is causing my problems....while we're at it we're doing the clutch master and slave cylenders.. car off the road until probably friday and at a bargain cost of $1200 .... I so want to start on the engine bay but things keep breaking!
Lesley :D
Does he mean the release pivot? Those things break a lot on SR20 gearboxes. Basically if we upgrade the clutch we have to change the pivot to the nismo chromoly item or risk it snapping.
Looks like this:
no idea...he explained it over the phone...I haven't seen it yet. I was busy trying to get the RIGHT clutch for my car... the suppliers keep trying to give me the clutch for the standard rolla, not MY rolla.
raa guys are getting stupider by the day i swear
when my wifes vs berlina (family car) broke down the raa guy said
"crank angle sensor" one problem the spark plugs were still sparking... idiot
are u going to put a sports clutch in it while u have the chance???
cheers
scott
You'll find the turbo sportivo's won't have there own listing on any parts database apart from toyota's. The clutch will probably be the same as any 7AFE, same flywheel, as the turbo gear is just a bolt on. Just get any exedy heavy duty and you'll be laughing, use a 100kw 4age clutch if think the HD 7AFE clutch might have a weak pressure plate, call exedy they'll know the deal, fairly certain the 7AFE runs a 212mm clutch. The average parts interpreter these days don't have a clue :D
I'd be asking about the cost of $1200, seems a bit overpriced if he's just replacing the clutch pivot, or did it snap off, and he can't replace it and needs to swap the box or bellhousing.
Clutch pivot shoud just unscrew....
$1200 is exxy. Call Adelaide Clutch Service and ask what they list for a heavy duty clutch for a 7AFE with Turbo :D
see, Toyota have told me it's a different clutch to the normal corolla...I know that originally they came out with a TRD HD Clutch, but last year the cost of that was over five grand, so they sent my old clutch to get it matched.
I have calls in with three people trying to get the right parts etc, but I'll probably end up going with an extreem HD clutch with an organic plate.
Oh, and the 1200 is for the supply and fit of master and slave clutch cylinders and the clutch. I'm pretty happy with the price.
Lesley :D
Edited by SoulSearcher
Lesley :yes:
Still wayy too expensive. Should be well under a grand to get all that done. Fitting a master and slave for the clutch is a bolt in affair and shouldnt warrant that much in labour costs on top of the parts.
I'd seriously look at sourcing the correct parts yourself and get someone to fit them up, as opposed to getting a mechanic who will get them at trade price and then jack up an 80% mark-up on the price which will be well above what they would retail them for.
don't get sucked in because you're a chick is all I'm saying, and well, $1200 sounds like you're getting sucked in. :D
Edited by Raven
considering the gearbox is the same across the range of the ae112 (note including the sportive)
exedy have a couple of clutchs in there sports tuff range.
heavy duty kit - part no. TYK-6932 HD
heavy duty button kit - part no. TYK-6932 HDB
then the also have a racing clutch
stage 1 sports ceramic kit - part no. TYK-6932 SC
this is all according to there website of course
yeah, 1200 sounds like alot for that,
get yourself the bits you need, even though it is a turbo rolla i doubt the master ns lave will cost that much,
clutch will depend on what you want but for a heavy duty organic it shoudlnt be more than 300
I'm still not too sure if the clutch is the same across all the range..they don't actually have a listing specific to the turbo, and I'd hate to get the part then find out it's the wrong one.. I'm STILL waiting on calls to find out about the parts.
I did go online to the exedy site and I got the part numbers and sent them an email to confirm that they're the same.
The cost of the clutch was 409 (but I have had a couple of cheaper quotes but only by about $30 ish bucks) and labour was going to cost $500 which I thought was fair, because he's put off a couple of other jobs to do mine quickly......
on another subject....I got an email this morning, they want me and my car at toyota head quarters for a photo shoot (for the toyochamp trophy presentation). I told them I needed a week!
Lesley :D
hey thanks cuzzo, I don't usually go to toymods,
I got a call from my mechanic. The car's done ;) although, I had 2 days of running around like a blue assed fly trying to find the right parts, and found out more about my car in the process ;) .... but now ..... my turbo flutters, sounds cool, but now that has to get looked at....
ho hum......
