I have a VDO tacho installed in my car. It worked fine with the standard points style ignition, but since i changed over to an electronic ignition with my 5k, the tacho doesnt work.
I've read that the negative wire from the tacho may have to be wired in series with the negative wire that goes to the coil.
The tacho also has five switches on the back. I realise that these switches have to be in the correst position. But what positions are right - the only info i could find related solely to tacho's with 6 switches.
There are 4 electrical terminals on the back of the tacho too.
Thanks in advance.
