Bp5ey
demuire
4K/4K-C Plugs
NGK - BP5EY
AC Delco - 43XLS
Denso - W16EXU-1
4AGE Plugs From 1986-88
NGK - BCPRE5-11 (1.1mm Gap)
AC Delco - FR2LS
4AGE Plugs From 1989 onwards
NGK - BKR6EP-8 (0.8mm Gap)
I could probably cross-reference these over at work to Bosch plugs, but NGK, AC Delco and Denso plugs outweigh the effort of even wanting to do that as Bosch plugs arent all that great.
*Added this to the Knowledge Base/FAQ as well.
Edited by Raven
And while talking about K engine spark plugs.....
If you have a 5K dished piston engine, you may use the longer electrode spark plugs from an EA falcon.
Part No. BRE527Y-11
They have a 1.1mm gap so you will have to reduce the gap to .8mm for a K engine.
MAKE SURE YOU HAVE A DISHED PISTON 5K FIRST!!!!! Putting these spark plugs in a normal flat piston engine will damage something for sure.
Edited by Xany
Iridium and platinum plugs can be damaged by gapping them, they've only got a really thin coat of noble metal, and if you chip it they'll corrode.
Like hell they are!!!! :(
Yeah I know they're supposed to be, but never are, so an extra 2 minutes will a feeler guage is always a good idea! :(
