August 28, 200818 yr comment_271071 how do you take the water tube off the bonnet?? so i can get the bonnet off? like where it is connected for the water to go on the windscreen help pleasee wanting to do it asap Report
August 29, 200818 yr comment_271079 Should be pretty obvious mate. There should be a clear (or brown by now) hose running the the under side of the bonnet, disconnect this from the bonnet, or from the pump on the bottle. Report
August 29, 200818 yr Author comment_271080 that was the question lol how do you disconnect the hose? because it wont just pull out?? Report
August 29, 200818 yr comment_271082 that was the question lol how do you disconnect the hose? because it wont just pull out?? Might have to cut it off and then get some new stuff, its pretty cheap! :sob: Report
August 29, 200818 yr Author comment_271083 hrmmmm :sob: i want to do it so i can get the bonnet off to sand underneath it, i hvnt done much to the car lately with dad doing his stuff (bodywork etc) so i wanna show that i am capable lol hope he wont get annoyed if i cut :hmm: ill give it til 12 if no one says a way to get it off ill just cut :cool: Report
August 29, 200818 yr comment_271084 hrmmmm :sob: i want to do it so i can get the bonnet off to sand underneath it, i hvnt done much to the car lately with dad doing his stuff (bodywork etc) so i wanna show that i am capable lol hope he wont get annoyed if i cut :hmm: ill give it til 12 if no one says a way to get it off ill just cut :cool: You gotta think the plastic is like 30 years old....... so its gunna be bloody hard to get off! Hope u get it sorted cheers Leigh Report
August 29, 200818 yr comment_271114 If you cut it right against the plastic fitting, then when you remove the remnant left behind, you should have enough left to just reattach. Report
August 29, 200818 yr comment_271145 coulda poured boiling water over it! shouldv'e loosened it up! Report
September 1, 200818 yr comment_271900 or a lighter, its alot easyer to put back on (if ur reusing the old stuff) if you heat up the little bit that conects back onto the window washer. if you heat it up life is just that little bit easyer Report
