November 13, 200818 yr comment_289785 Bought this off a retiree a couple of weeks ago. He bought it in 1990 and has babied it since then. When we found it, the van had been sitting in the garage for months. Came with thousands of dollars in maintenance receipts. Poor guy got ripped off bad by his mechanic. Initial plans are to fit quad headlights and subsequent front guards, wheels, flare the guards, tint windows, new windscreen, straighten bumpers a bit and add some fixed back seats. Hope you like. Edited November 13, 200818 yr by Queen20v Report
November 13, 200818 yr comment_289787 looks neat, does it have a 20v like your username suggests? Report
November 13, 200818 yr Author comment_289798 Gotta love that blue vinyl and the AM only radio! Report
November 13, 200818 yr Author comment_289799 looks neat, does it have a 20v like your username suggests? Nah, that was my old ae82. :jamie: I killed it... Thought I'd better keep the same username though. :yes: Report
November 13, 200818 yr comment_289800 yeah fair enough, I have no idea how you managed to find such an immaculate corolla, I wish I had it! although I don't like the aftermarket windows Report
November 13, 200818 yr Author comment_289805 I can't believe it either. Apparently heaps of people called about it but nobody turned up. We were so excited when we saw it that we hardly negotiated on the price because we felt bad for ripping off a pensioner. Lol. I like the windows but want different seals around them. Report
November 13, 200818 yr comment_289810 it looks to be in very good condition. please don't flare the guards :jamie: ! Report
November 13, 200818 yr Author comment_289823 Thanks :jamie: Does anyone know what width 15 inch rim we can fit with the stock guards? Will 7.5 inch fit or is that still too wide? That's about as narrow as we want em, otherwise we have to live with less dish. :yes: Pretty keen to do reversible mods in order to keep it as original as possible though. All the stockie parts will be carefully stored in the shed. Report
November 13, 200818 yr comment_289824 just roll that lip on on the inside of the gaurd and you will be fine with the right offset. Try a +20 to +10 wheel and you will have room to spare Edited November 14, 200818 yr by Sam_Q Report
November 13, 200818 yr comment_289826 overrated van queenie! change the seals for sure, match the door???? Report
November 13, 200818 yr Author comment_289828 Do you mean match the window seals to the door seals? I totally agree. The window ones are so chunky! Report
November 14, 200818 yr comment_289878 Car looks overrated! The amount of dish a wheel has depends on the offset of the wheels. A 8.5" wide wheel with an offset of -10mm will have the same dish as a 4.5" wheel with an offset of -67mm for example (if you can even find it in those specs). It's just easier to find dish on wider wheels because as you go wider, the offsets also goes wider (lower). If the panel van guards are the same as the sedan guards, I would recommend 15x7 +5 offset up front and 15x7.5 -5 out back or somewhere around there. Depending on the ride height, only a roll of the guards is needed. If you want 7.5" minimum then a offset of +12mm will sit the same as the 7" +5 for the fronts. Good luck with it! Report
November 14, 200818 yr comment_289892 Minta! thats hell clean especially for a panno. don't mod it ey leave it pretty stock just roll that lip on on the inside of the gaurd and you will be fine with the right offset. Try a -20 to -10 wheel and you will have room to spare ? a 7.5" wide rim with an offset of -20 is not going to sit inside the guards with 'rolling of the inside lip' lol Cheers, Ben. Report
