  • Replies 57
Well my brother had today off work so he decided he needed something to do, so he made a couple of small metal plates to fill in the gap on each side of the gearlever where it enters through the floor. :P
He also put the auto console back in. :dance:
So all going well it should be a runner by the weekend. :wink: :yes: :yes:
I got the crossmembers welded together at work yesterday and I am just waiting for a new gearbox mount which should be here tomorrow. :y:
Heres a pic of today's progress. :yes:
Fantastic bargain! A $400 bank account balance for me makes it difficult to keep adding to my Corolla collection.
I love the interior, looks flash! Should look at putting some nice rims on it. Something clean and respectable though
to suit the car. Good luck with the beast and in the words of ke20rolla...
Long live the Rolla's. :y:
lol :|
My gearbox mount arrived today so tonight I bolted in the crossmember, filled it up with oil and put the tailishaft in :jamie: So all I have to do now is wire the selector switch into itself, as it thinks it's in gear and it doesn't start, and sort out a couple of very small things like replacing a indicator dash globe, give her a oil and filter change and maybe replace suspect rear wheel cylinders.
Other then that, make sure everything is working for when I put it over the pits. :yes:
Edited by ke20rolla
Last night I gave the ke55 a oil and filter change, wired up the reverse switch, fixed a couple of blown globes, adjusted the brake pedal play, and wired the selector plug into itself so that it starts now. :jamie:
So this weekend I'll give her a good tune by cleaning the plugs, points and rotor and check the timing and mixture and grease the necessary parts etc. :|
Progrees is going along smoothly now. :yes:
Well it's been a while, but it's now registered and I'm driving it around. I put in a c.d player and a couple of speakers on the rear parcel shelf aswell. :yes:
It's also got a straight front bumper. :y: :D I have also replaced the brake pads, shoes, flexible lines, rear wheel cylinders and machined the rotors, I also put in new nolathane front swaybar bushes.
The next things on the list are to get some rust cut out of it and straighten the drivers front guard, then find some 14 or 15inch mags to go on it. :(
Cheers, Mark. :P
Hi all, here is my ke55 with 17inch mags with 205/40 tyres. I went around to a few wreckers as I was originally going for 15inch mags but couldn't find any. :D
So I got some new 17inches as there wasn't much choice, anyway I reckon they suit the car very well. :D I have also lowered it and put on a 32/36 downdraught weber for a little more pickup. :cool:
I still need to find a straight drivers side front guard, PBR brake booster and cut a little rust out here and there.
Anyway I'll sort it out eventually and it will end up as a neat daily. :abuse: :D I am also going to tint the windows. Here is a couple of pics. :abuse:
Thanks Murd, :locked: Yeah I am usually the same with modern rims on old cars, some people don't have a clue what suits what, but these seem to go well with the body shape.
Should look even better when I get the windows tinted. :yes:
Thanks, Mark. :y: :y:
They are actually the only type of modern rim that i like on the older corollas. If it has anything more than 5 spokes then it shouldn't be on a rolla. Looks the goods man. Must be a sweet daily.
Hi guy's, well I managed to pickup another PBR brake booster and a straight rust free drivers front guard today. :D :cool:
I put the booster on this arvo and the brakes are working much better :yes: So all I have to do now is get the new guard painted and and get a little rust cut out, tint the windows and I should be just about done. :dance:
I'll post some more pics when I've completed these things. Cheers, Mark.
