kiahn Posted December 21, 2008 Report Posted December 21, 2008 ok here is what is happening, when i stop at lights in any gear apart from 1st its lil fight to get it into first and sometimes any gear. but... if i am moving the gears are as smooth as anything. is it my syncro gears or is the whole thing f***ed? also would it be better to buy t50 or k50 as replacement if needed? Quote
kiahn Posted December 21, 2008 Author Report Posted December 21, 2008 i really need help as i don't know if it will lock up randomly or completely fall apart. its got me and my dad (whos owned 2 ke70's) stumped Quote
KE30_KE35_KE55 Posted December 21, 2008 Report Posted December 21, 2008 i really need help as i don't know if it will lock up randomly or completely fall apart.its got me and my dad (whos owned 2 ke70's) stumped Try adjusting your clutch if that doesn't work drain and replace the gearbox oil. the syncro should be like new on first gear. Quote
kiahn Posted December 30, 2008 Author Report Posted December 30, 2008 my gearbox has started to make a click, that i can feel when i hold the gear stick, in all gears. the clutch initiates almost as soon as you touch the pedal so i doubt this need changing. I'm thinking about going out and buying a 5-speed (k50) so that i can go on the freeway without having to listen to my engine whining ive already started to work on my 4k, getting exhaust in few days and weber is on the way is there a gearbox with a better ratio for a worked 4k? Quote
kiahn Posted January 1, 2009 Author Report Posted January 1, 2009 thanks i will take a look and see if it is the spigot bearing. ill get 5 speed first tho and see if this fixes it, if not Bearing here i come Quote
TRD ke70 Posted January 1, 2009 Report Posted January 1, 2009 sounds like the pressure plate has shit it's self, this would be why the clutch pedal is so high and it's hard to get into gear. Quote
kiahn Posted January 2, 2009 Author Report Posted January 2, 2009 sounds like the pressure plate has shit it's self, this would be why the clutch pedal is so high and it's hard to get into gear. is it just a clutch kit that i need to buy or a couple of extra things? also would it be worth me buying a k50 gearbox to replace my current k40? Quote
TRD ke70 Posted January 3, 2009 Report Posted January 3, 2009 (edited) clutch kit and a spigot bearing as well. maybe look at getting the flywheel machined, there's mobile guys out who'll come to you. you could replace the old K40 with a K50, would make it nicer to drive at 100k's. Edited January 3, 2009 by TRD ke70 Quote
kiahn Posted January 13, 2009 Author Report Posted January 13, 2009 yeh k50 sounds good aye, but if it was my clutch wouldnt it disengage almost as soon as you start pushing the pedal? ill go thru everything here and see if it fixes it, Quote
Taz_Rx Posted January 14, 2009 Report Posted January 14, 2009 No its not fully disenguaging, this is why you can't get it into gear. Quote
corollaart Posted January 14, 2009 Report Posted January 14, 2009 I would drain gear box oil first may find all your problems at once :| Also check clutch fork is not split.Just my 2cents worth Quote
LukeAE71 Posted January 14, 2009 Report Posted January 14, 2009 Clutch pressure plate is screwed bud. Had the same problem on my Supra. Advise to stop driving immediately as you are screwing your gearbox by driving it like this at the moment. Only marginally I would say but nevertheless you will screw it eventually :| Quote
