hey guys just wondering if there is any reason as to why my fuel pump on my KE70 has stopped working again, i replaced the original about 2 months ago now the new one i replaced it with has also stopped working. Is there any common reasons for this? any help would be greatly appreciated.
stopped working or the diaphram f@$ked out?
ethanol fuels?
turned the motor over with the top of the fuel pump off to check it i noticed it was pumping very fast and it also seemed like the diaphram wasn't working very well, and no ethanol fuels
its was a new pump
I can read!!!!
Fuel miser had a bad batch of pumps made up a while ago where the diphram was faulty and you would have to push the arm up over half way before it would work, Mine worked occasionaly.
I can read!!!!
i just assumed because it was new there wouldn't be a problem, i guess next time i'll have to check that.
