hay guy's last week i drive my ke30 down the coast for the week (new year's)
and when i got back i noticed when i pulled my oil cap of
my 3k motor it was blowing white smoke and it smelled like
fuel really bad this has never hapend to me before.
is this bad??????
cheers
shaun.
Good point, yes i suppose they can if the diaphragm tears.
Id pull it out and check it ASAP. Unscrew the top half of the pump and inspect the rubber diaphragm for holes etc.
You should have noticed running issues with a leaky diaphragm though, like leaning out/stalling at high revs.
yeah i had a fuel pump let go on me a few months ago, got 100 kms to the tank of fuel and went - woha, wtf ?
Oil level was high, smelt horrid, was very thin..
lol, luckily she didnt go boooooom
Yeh by the way shaun, yes this is bad. Don't drive it until you've determined the problem.
If your motor doesn't go bang, you might do some damage thanks to the new lubrication properties of the oil haha.
Edited by philbey
Ill join teddys club.
Yes K motor pumps if they tear will leak into the sump...BUT
Toyota put a small hole in a pumps base so if it tears fuel will leak out there. Well this shitty hole gets blocked still in the box pump comes in. I don't think I have ever seen mine unblocked attracts oily shit.
So id check the oil.
Mine went one day I had like no fuel in the tank (ws on way to servo) and lost fuel in carby and gone oh I'm out car was like 1km from home get home to put mower fuel in then go and noticed hey I can smell fuel and well I looked and found. So be careful don't wanna wash your motor out..LOL
Cheers
Cameron
can go both ways they have 2 seals 1 for oil 1 for petrol so you can fill your sump up with fuel and you can fill the fuel system up with oil. i've seen people reco a motor because of a dodgy fuel pump
yeah when i give it abit it just splaters some time's
its also idoling as 1100 rpm and i can't seem to get the idol
lower (the idol skrew is all the way out) my be timeing problems!
and i think I'm leaking some oil from the side of the sump
under the fuel pump!!!!
(but that mite be the fuel pump valve leaking)
if it goes boooom then ill have to put my 5k in sooner lol
cheers thanks sofar guy's.
