March 15, 200917 yr comment_327905 hi all i was doing some info on coverting a 7k into my ke25 ...it is saying that the 7k will bolt straight in to a ke so what needs to be modified besides the sump cheers guys oh and that means i have to run injection can i buy a manifold for webbers Edited March 15, 200917 yr by brendan Report
March 15, 200917 yr comment_327910 7K's came out with both EFI and carby'd. Ive been told that you can use either 7k mounts. 3/4/5k mounts can be used, but may make the engine sit a little bit higher. Report
March 15, 200917 yr comment_327920 it will not bolt in. It is wider than any other K motor. The mounts need to be "massaged". The drive train needs to be upgraded - gearbox, tailshaft, diff. Rear diff will have larger breaks, which means you'll need to even up the fronts by upgrading them as well. Chances are you'll want to get the thing boosted on the brakes. Most of the gearbox's are hydrolic clutch assy, which means you'll need to integrate a hydo pedal box assy. Oh, and the sumps need to be quite heavily modified. Bolt in = absolutely not. i would love to find this unique source of info which keeps providing the world with "7k's just Bolt in". hahaha :lolcry: Report
March 15, 200917 yr comment_327926 From what ive read, the 7k is wider but the original 7k mounts are thinner which compensates. pretty sure there wss a member in vic (78 7k Rolla i think) who used the standard 3k mounts. Report
March 15, 200917 yr comment_327931 The drive train needs to be upgraded - gearbox, tailshaft, diff. Rear diff will have larger breaks, which means you'll need to even up the fronts by upgrading them as well. Chances are you'll want to get the thing boosted on the brakes. Most of the gearbox's are hydrolic clutch assy, which means you'll need to integrate a hydo pedal box assy. Oh, and the sumps need to be quite heavily modified. So does this mean you would need a t50 or something to run a 7k?? I always thought you could just use a normal K gearbox. :lolcry: Report
March 15, 200917 yr comment_327939 So does this mean you would need a t50 or something to run a 7k?? I always thought you could just use a normal K gearbox. :lolcry: You can use the standard gearbox. They may have a wider block but it narrows down for any kseries gearbox. Just the sump needs a little tap to make it clear.. Standard driveline will be fine as long as you don't give it complete death all the time ,but obviously youll probably end up breaking things with a 4 or 5k anyways if you abuse it enuf.. Great conversion from what iv heard and seen.. I havent done this conversion myself but it was only last week i was having a chat to a guy with one in his ke30 over here in New Zealand and he said it was 'as easy as bolt in and away you go pretty much'.. Sam Report
March 15, 200917 yr comment_328088 From what ive read, the 7k is wider but the original 7k mounts are thinner which compensates. pretty sure there wss a member in vic (78 7k Rolla i think) who used the standard 3k mounts. Yes, i used standard 3k mounts but the sump needed to be seriously modified to clear the crossmember. You can use the standard gearbox. They may have a wider block but it narrows down for any kseries gearbox. Just the sump needs a little tap to make it clear.. Standard driveline will be fine as long as you don't give it complete death all the time ,but obviously youll probably end up breaking things with a 4 or 5k anyways if you abuse it enuf.. Great conversion from what iv heard and seen.. I havent done this conversion myself but it was only last week i was having a chat to a guy with one in his ke30 over here in New Zealand and he said it was 'as easy as bolt in and away you go pretty much'.. Sam Where are people sourcing their info from? Rubbish a little tap will help the sump clear, i'm presuming it could be even less clearance in an older rolla. Do not consider this conversion if you are strapped for cash and/or not very mechanically minded/experienced/talented. Report
March 15, 200917 yr comment_328133 Do not consider this conversion if you are strapped for cash and/or not very mechanically minded/experienced/talented. says the one who still hasn't got a proper gearbox :laff: :lolcry: Report
March 15, 200917 yr comment_328139 The source poeople are getting this from (7k same size as other k engines) is Rollaclub!! Someone linked to the thread when asking about a 5k on Friday. Link All K blocks have the same bellhousing studs and engine mount points, so you can drop a 7K in place of your 1K without a problem. Someone please alter this! Edited March 15, 200917 yr by 67Rolla-Ken Report
March 15, 200917 yr comment_328140 says the one who still hasn't got a proper gearbox :laff: :lolcry: Ouch man, that burnt! It's a matter of time before the upgrade is done. Having said that if you don't do 'abusive' driving the driveline will hold up fine. Report
March 15, 200917 yr comment_328143 Someone please alter this! Everyones got access.... that means :lolcry: you could! Report
March 16, 200917 yr comment_328249 First Of All, I would Like to Introduce my Self, My Name riza from Indonesia, I'm looking for repair manual book for Toyota 7K Engine, Does any Body Can help Me ? I have Tried to Download from this site, but always failed, The Page Don't found... Please I really appriciated any kinds of help... thank you Report
