Really Stupid Question
hey - yes, i did a search, but it didnt bring anything up.
iv decided to drain the oil for once in my k40 g/box, does anyone know what size socket to use to remove the drain plug ?
cheers David
haha, after going through my complete socket set,
we have found it.
its a 24MM socket :P
thanks for your help guys :)
first g/box oil change in about 5 years :D mmm yummy
haha, nah, i just fill it back up through the shifter hole - it takes around 1.5 ltrs,
my sump drain plug on the engine (3K) was a 19mm, but my new engine is only a 14mm (3SGTE)
thanks for all ya help dudes
gearbox plugs are huge, i had to buy a socket just for draining boxes. there are at least 3 different engine sump bolt heads.
i also just drain the box out the bottom and full thru the shifter hole like zigen. i've ever even taken a filler plug out of a K box :)
well hows this for odd, the corona's one is 26mm!?!
what the??
y'all need to take the clutch off a mini, it's like a single 1.5" nut
Gotta love taper fit flywheels in confined spaces NOT! :P
haha someone who knows :P yes, on top of that, the flywheel is held onto the engine by a taper which needs about 10 million ft-lb of torque to release
luckily, we know an old mini mechanic, who has done this many thousands of times himself, and has made up a custom puller which would probably be the most ingenious piece of engineering ever, and lets you get the flywheel off still in the engine bay
