hey guys i can really find anyinfo on these motors at all on the net all i know is there about 77 hp and they are twin carb i am looking at purchasing one of these motor for my ke55 drift pig because i guessing there reasonabley cheap ? and very easy to put in to me 55
does anyone have anymore info on them what they worth ?
were to get one from
:P
"How To Build A Tough "K" Motor"
The "Frequently Asked Questions/Knowledge Base" Should be able to help you out a little. There are no 3k-b
"dealers" around as they are a 40-year-old engine. The twin carbs are just a factory item and aren't really
better than aftermarket options such as the popular Weber or Dellorto carburettors. The "b" stands for
Bigport Head, which means the ports are just a little bigger than standard ports - again, which is a 40-year-old
design. Basically it's the exact same as any other 3k motor, but with a bigport head and 2 carburettors.
If you wish to turn your KE55 into a drift pig, I suggest you stick with your 4k (if that's what's in it), which are
decently better than a 3k motor - or even upgrade to a 5k motor and then do a bolt-on carburettor setup
and mild porting job on the head which will give much better results than a 3k-b as I highly doubt that you
will be able to do any decent drifting with a 1.1L 40-year-old engine (and barely with the 4k or 5k)
Good luck
Edited by seabiscuit
ok well i noticed they make like 18 more hp thought it my be the way to go if i can get one cheap even if just get the hea cleaned up and ported and use the 4k and twin carbs ontop of me 4k ?
ive read all that three times over but i just thought getting this twin car motor will be way cheaper then other carbs and stuff. my 55 would be pretty light i reckon no sound deadning or interior or bumpers left on it just 2 front seats
what I'm saying i can get my hand on 3k-b which has been rebuilt bout 30k ago has a mid range cam and twin carbs and stuf this has more toque then a 4k so wouldnt i be better or getin if for say 200 bucks then?
or would i b better/cheaper buyin a decent carb for mine and getting a cam
If you can buy it for $200 go for it.
A 4k with similar mods is going to be quicker, due to more torque.
In a porky arsed ke55, you would be better off going with forced induction, or putting your money towards a conversion with something like a 2/3T or 4age.
thats ok to say that but i don't have the money to go forced.
my idea is to go the 3k head get it ported and just cleaned up and get the head surfaced. and carbs rebuilt ? with my 4k bottom end and find or buy a nice cam for it with some extractors exaust.
will this be enough to get my wheels to turn with a full spool and a very stif and lightchassis
....maybe in the wet! :P
Honestly dude, if you have $200 to spend on another K motor then sit on it until a 5k comes up for sale within your budget.
More power, more torque and you're effectively not trying to polish a turd!!! :P
new idea 3k head and carbs wid 5k bottom end cam extractors. i think it wil be fine the 4 k made the wheels spin so i think illbe fine if not i gjust embaras the fuk out of my self out at drift prac
5k bottom end/3k head is the combo I run for LOW COMPRESSION.
don't waste your time/money, i did abit of drifting with a 5k turbo in my ke70 wagon and by the end of the day your just pissed off because it wont do what you want/need it to, all good for a clutch kick around a corner to get some slide action but no good for switching and holding drifts, in the wet its a differant story, my car ruled in the wet, but thats just cheating
in the end i ditched it and wacked a sr20det in, now i have fun all day and even have smoke lol
i just don't have the money to do something like that
but i think i have th mechaical tools to pull appart a motor and rebuilt one.
i really just wanna get out there and give it a go
and othere wise it just a waist of this ke its got flared guards and all hahah lol
maybe it will be on the raining drift prac days ill go lol.
i wanna do hydralic handbreak to whick would help.
Waste of money trying to make a K motor into a drift car.
You'll spend a quarter or even half of what you'd need for a 4age conversion and will be disappointed
as you still won't be able to drift in the dry.
