May 15, 200917 yr comment_345066 My quest for a dirt cheap race car has come to the point where I modify the stock shocks for much stiffer damping. My question is this are the rear mounts up to handling really stiff shocks? Mod to the shocks will be thicker oil... I'll include photos when I do it Edited May 15, 200917 yr by vagen Report
May 15, 200917 yr comment_345081 Dirt cheap mods could as simple as getting some bike shocks, removing the spring & then you can re-valve to suit...... cheaper than some race shocks. Outside the square tiger! :y: Report
May 16, 200917 yr comment_345102 early commadore station wagon rear shocks fit, as they carry a lot more weight than a corolla, I'm using a set of pedder sports rider commadore shocks in mine and they handle fantastic, try and find a rear sway bar as well, from a ke55 onwards. Report
May 16, 200917 yr comment_345136 only use the rear sway bar if you are running a LSD or locker, or if you are only driving on open sweeping corners. If not you will single spin to a stand still in tight corners. Definitely go for the Commodore wagon shocks, work a treat. Report
May 16, 200917 yr comment_345146 The Commodore wagon KYB shocks that fit have the part number 343113 if you do go down that path. Report
May 16, 200917 yr Author comment_345147 UM anyone notice my location? unfortunately no holdens made it here till 2005 Report
May 16, 200917 yr comment_345232 Didn't do it to the rears, but did refill the front struts with a thicker oil to increase stiffness. Worked well until the oil seals were eaten away. If you do this, use a proper hyrolic oil not engine oil like I used. Report
February 11, 201016 yr comment_412907 I know this is an old thread but would the commodore rear shocks work on the back of my ke20? Report
February 11, 201016 yr comment_412912 Didn't do it to the rears, but did refill the front struts with a thicker oil to increase stiffness. Worked well until the oil seals were eaten away. If you do this, use a proper hyrolic oil not engine oil like I used. i replaced my front oil with the thickest motorbike fork oil, what a waste of time that was! didnt even notice a slight difference! Report
February 11, 201016 yr comment_412977 sure do mate, VH wagon shocks, huge difference :wink: :yes: :( Report
