June 15, 200917 yr comment_352264 hey guys I'm new to this site just wondering if i could grab any help with what diff to fit in my ke55, one without a lot of stuffing around. any help would be apreciated. :yes: Report
June 15, 200917 yr comment_352391 The stock one is normally a goer for fitting properly. (maybe a bit more info of what you are trying to acheive and someone might help you). Report
June 15, 200917 yr comment_352425 I think any ke30-55 diff would fit in pretty easily. I just changed mine from ke35 to ke55 to stop it revving so high etc. Only thing is if you put in a different diff the speedo will most likely go out. But that's only if you want to interchange your average stock diffs, if your looking for a specific performance or whatever than others can be used, and I'm sure someone here would be happy to tell you which 8/ Report
June 16, 200917 yr Author comment_352500 The stock one is normally a goer for fitting properly. (maybe a bit more info of what you are trying to acheive and someone might help you). ohh sorry guyss a diff so i can have less traction.. (lsd or locker..) any help thanks.. Report
June 16, 200917 yr comment_352502 a diff so i can have less traction.. (lsd or locker..) LSDs tend to give _more_ traction, not less...... Report
June 16, 200917 yr comment_352505 soak your tyres in diesel or gearbox oil to obtain less traction. Edited June 16, 200917 yr by the witzl Report
June 16, 200917 yr Author comment_352508 soak your tyres in diesel or gearbox oil to obtain less traction. that sounds pretty stupid Report
June 16, 200917 yr comment_352515 that sounds pretty stupid so does trying to spin two wheels instead of one with the same amount of power going to them. Report
June 16, 200917 yr Author comment_352521 so does trying to spin two wheels instead of one with the same amount of power going to them. ok pretty much what locker will fit in my car???? any help no sarcasm pleasee.. Report
June 16, 200917 yr comment_352531 Just weld it. If you had a ke30 all you would need to do is drain the oil and take the plate of the back of the diff and you can weld it while its still in the housing. With a ke55 you will need to pull the center out to weld it (i think??? never pulled one apart). Then get a window washer setup, fill it with diesel, position a jet each side of your car so it sprays onto the back tires and do sum spinny's. Report
June 16, 200917 yr comment_352534 haha good brent i like that!! or wait for rainy days or head to a gravel road!!! Report
