hey guys
I'm new to this site just wondering if i could grab any help with what diff to fit in my ke55,
one without a lot of stuffing around.
any help would be apreciated.
:yes:
The stock one is normally a goer for fitting properly.
(maybe a bit more info of what you are trying to acheive and someone might help you).
I think any ke30-55 diff would fit in pretty easily. I just changed mine from ke35 to ke55 to stop it revving so high etc.
Only thing is if you put in a different diff the speedo will most likely go out.
But that's only if you want to interchange your average stock diffs, if your looking for a specific performance or whatever than others can be used, and I'm sure someone here would be happy to tell you which 8/
ohh sorry guyss
a diff so i can have less traction.. (lsd or locker..)
any help thanks..
so does trying to spin two wheels instead of one with the same amount of power going to them.
ok pretty much
what locker will fit in my car????
any help
no sarcasm pleasee..
Just weld it. If you had a ke30 all you would need to do is drain the oil and take the plate of the back of the diff and you can weld it while its still in the housing. With a ke55 you will need to pull the center out to weld it (i think??? never pulled one apart).
Then get a window washer setup, fill it with diesel, position a jet each side of your car so it sprays onto the back tires and do sum spinny's.
