Again not much has changed except the Engine capacity and related measurements.
I THINK this is a 4K
Engine
Engine Displacement (cc): 1290
Firing Order: 1342
Spark Plugs
Type: Denso W16EP
Gap (mm): .80
Compression Pressure (psi): 127-156
Distributor
Make: Denso
DWELL: 52±2
Point Gap (mm): .40-.50
Ignition Timing Initial/Static: 8@Idle C/S
Fuel System
Make/Type: Aisan
Float Level (mm): 6.5
Idle Speed (rpm): 750±50
Emission CO%: 0.3-2.0
Fuel Pump Pressure (psi): 2.8-4.3
Fuel Capacity (cc/min@rpm): 900@5800
Oil Pressure (psi): >45@3000
Valve Clearances
Inlet Hot/Cold (mm): .20
Exhaust Hot/Cold (mm): .30
Torque Specification
Cylinder Head (ft.lbs): 39-47
Main Bearings (ft.lbs): 47-49
Con Rods (ft.lbs): 29-37
Alternator/Generator
Make/Type: Bosch
Output Amps: 40
Output Voltage: 14
Regulator Settings (V): 13.8-14.8
RPM: 1000
Starter Motor
Make/Type: Bosch
Cranking Current Draw: 55
Locked Current Draw: <500
Cranking Voltage: 11
Wheel Alignment *Settings Unladen*
Castor: 1°50'±20'30"
Camber: 0°45'±30'30"
Toe-In (mm): 1±1
  • 9 months later...
mate your motor should be a k4-c. it should be imprinted into the block on the drivers sie of the motor, and looking at some of the specs of the engine, i would say it is a k4c. they're are a good engine. mines done 142,000 km, first time around and no rebuilds.
the C stands for Carby......
hmmm......i wonder weather that would make mine a
5K - W.......hehehehe..... W = Weber...
Edited by Xany
Actually I thought the C was just a designaton given for emissions friendly engines, possibly C for California, the first place they really started cracking down on this sort of thing? 3K-B was the high compression twin carb motor, and there was a 3K-d as well...... *shrugs*
Thoughts?
meh.....i still reckon its easier to remember that c = carby....
hehehe....even though its wrong.....its still right in a way....buggered if i'll be saying that my engine is related to america.
just for confirmation..
Engine Codes
C = emission package (California)
Edited by Xany
I'm not so sure the "-C" in 4K-C means california emissions.
the americans had air injection pumps on their engines. these pump air into the exhaust ports of their engines, to dilute the exhaust gas emissions. we didn't get them on our 4K-C's. their 4K-C is different to our 4K-C.
