i got a ea resinator lying in the shed, I'm thinking to remove the ke55 one and put the ea one in and rip the baffles out the muffler?
would it be tooo loud and sound like arse?
More research needed... There are three or four popular designs of muffler-
*Straight-through with angled holes and fibreglass packing. Noisiest.
*One pipe like above, but bent into an 'S' inside the casing so it is a bent-straight-pipe. Quieter but still rorty.
*The inpipe goes through 1/3 of the muffler with holes and f'glass packing, then an empty middle 1/3 completey open, then the exit pipe goes out the final 1/3 via holes and f'glass. Better flow than stock and better noise. Quieter than either above.
http://z4.invisionfree.com/lexusaltezzaclu...ic=2629&hl=
*The typical one where a pipe goes all way down one side, the gases make their way back up to the top, then the exit pipe runs all the way down the other side.
http://forum.altezzaclub.org.au/index.php?showtopic=2421
The thickness of the outer casing is crucial in stopping drumming and resonating inside, some have three layer casing (steel, f'flass, steel) othrs have quite thick stainless outer walls. Whatever you use make sure its heavy...
..and more recent designs with outside pipes and/or the adjustable flow paths using a remote.
I have a nice design if anyone feels like making a production run of say 5 units...
These mufflers are actually louder than straight through designs as they have less absorbtion into
the glass packing. Straight through mufflers work BEST on everything (any car. any engine, any
exhaust system). The trick is to use the right size muffler. The more volume the muffler has the
the quieter it will be.
i cut my original muffer apart last nite and removed all the baffles, question how will it sound?
loud when giving it the stick?
only loud when I'm flat out with my fat and quiet when crusing?
drone and loud all day long?
omg lets make my 4k sound like a tractor!!!
if you take the exhaust baffles out/mufflers off your k engine (or anything else) it will be incredibly loud, attract the attention of police (and the sort of trashy feral girls you see walking the ghetto around here) and it will send you deaf. it will drone really bad, and sound more like a tractor than anything else...
oh and you won't get a gain in power either.
if your engine is stock or close to it get a 1.75" system with straight through perforated tube resonator (as long as you can fit under there) and a straight through perforated tube muffler, preferable with a 2" or smaller tip, and it won't be droney and will actually sound nice when you get into it.
if you have work done to your engine, go a 2" system.
Robert.
