September 30, 200917 yr comment_378010 hello i have an electric fan relay out of a ke70 which is 15A.. but i want a 30 A relay...form which toyota car i can find a 30 A relay? Report
October 5, 200917 yr comment_379177 You will find it hard to find a relay to fit in that is 30A rated, you mite be lucky to find one from a Hilux 4WD. If you did try to pull 30A through the relay block there is also the chance you could burn it out! You would be better off putting in a slave relay that is fused connected to the battery? Edited October 5, 200917 yr by Crostek Report
October 6, 200917 yr Author comment_379592 of course the relay will be slave... my Ke30 does not have a relay box as ke70...and it has a mechanical fan also...! but my engine is a 4k out of a ke70 and i need a relay which will work with the ke70 temperature detect switch but 30 amps to work with a bigger fan!!! Report
October 6, 200917 yr comment_379604 My ke30 electric thermoswitch contolled cooling fan pulls 3.7 A (Looks same as a ke70 fan.) 30 A would be a realy strong fan. Suggest you measure the current of the fan youll be using. You need some fat wire for that kind of current If you want a relay that handels big amps look for glow relays out of diesels Report
October 7, 200917 yr comment_379867 15A sounds massive man, my 16 inch fan only pulls 5A and that moves enough air to taxi a 737 maybe you should look at altronics, aussie based company that is really good with prices Edited October 7, 200917 yr by kiahn Report
October 9, 200917 yr comment_380568 I didn't know KE70s had electric fans! My '83 doesn't! Does anyone know whats involved in converting mine from a silicon one to an electric one?? Is there a worthwhile power gain? Report
October 10, 200917 yr comment_380698 In europe they got electric fans. Theyre controled by a thermoswitch mounted in the top of the thermostat housing, and a relay. Doesnt cause any whiplash injurys preformancewise but there is a gain. Will give better milage as well. Mine hardly ever runs unless pushing it , but that would be due cooler climate Report
October 10, 200917 yr comment_380721 Well well... Can you take a photo of the sensor for me please? One fan or two?? Off to the scrapyard again... ;) Report
October 10, 200917 yr comment_380746 Well well... Can you take a photo of the sensor for me please? One fan or two?? Off to the scrapyard again... ;) One fan http://www.toyodiy.com/parts/p_E_1982_TOYO...DCDSW_1603.html http://www.toyodiy.com/parts/p_E_1982_TOYO...DCDSW_8401.html Report
