Is the old block a 4K or a 5K? Does your current motor have dished or flat top pistons? Valve springs are just there to keep the valves sealed doesn't matter how many there is, they'll just give your motor more potential to rev (if everything else is right) and waste a little bit of power if they're heavy duty.
The important thing is to run the head with the right dish volume so you don't end up with compression high enough for methanol, around 14-15:1 with a 5K head on a 4K bottom end.
Cool, as long as the head came off another dished motor you're laughing. Put the 2 heads side by side. If the replacement head is 1.5-2mm shorter it'll put the compression up too high, similar height all good.
