November 15, 200917 yr comment_391320 Hi guys, I have a problem with my 1986 AE82 rolla and I need some assisstance.. The front passengers side wheel has a squeak/rubbing noise coming from it and I don't know what it is.. It happens pretty much the whole time the car is rolling and it is really noticable at low speeds or when cornering. I haven't really had a chance to rip it apart and have a look, and I was wondering if anyone knows what it is?? And is it an easy or hard fix? I also have another issue, PINGING!! :) what could it be?! I have done the timing and it is running premium fuel, what else could it be? The engine is a stock A4-C.. Cheers Report
November 15, 200917 yr comment_391322 Hi guys, I have a problem with my 1986 AE82 rolla and I need some assisstance.. The front passengers side wheel has a squeak/rubbing noise coming from it and I don't know what it is.. It happens pretty much the whole time the car is rolling and it is really noticable at low speeds or when cornering. I haven't really had a chance to rip it apart and have a look, and I was wondering if anyone knows what it is?? And is it an easy or hard fix? I also have another issue, PINGING!! :) what could it be?! I have done the timing and it is running premium fuel, what else could it be? The engine is a stock A4-C.. Cheers if its fwd its most likely a constant velocity joint in the drive shafts Report
November 15, 200917 yr Author comment_391419 if its fwd its most likely a constant velocity joint in the drive shafts Yeah it is Fwd, is that an easy fix? And whats the price tag on it? Report
November 16, 200917 yr comment_391528 Yeah it is Fwd, is that an easy fix? And whats the price tag on it? there is a little bit of mucking about removing the drive shaft cost just a guess about 250 bucks Report
November 17, 200917 yr Author comment_391751 there is a little bit of mucking about removing the drive shaft cost just a guess about 250 bucks Ok, thanks man I appreciate it Report
November 19, 200917 yr comment_392343 if its not your CV, it could be brake squeal, check the condition of your brakes before you go popping your cv out Report
November 22, 200916 yr comment_392892 hey guys! i would like to know if AE90 hub assembly is the same as AE93?? i have my ae 90 in my back yard and need to replace the wheel bearings in my AE93, so if i can ill rip out the hubs in the 90 and press new bearings in then swap them for the AE93 hubs..... Cheers Tory Report
November 23, 200916 yr comment_393050 Well bearing kit part numbers are the same for AE90 all the way to AE93 haha I'm sure they would be the same for all AE9X models Report
November 23, 200916 yr comment_393058 About your Pinging... Had same problem with my AE82. Has the timing belt been replaced lately ?. What about the timing belt tensioner ?. Some folks replace just the timing belt at the regular intervals and neglect the tensioner. The tensioner goes weak allowing some slack in the timing belt. I had the tensioner replaced in my 4A-C and problem solved. No more pinging. Report
November 26, 200916 yr Author comment_393635 About your Pinging...Had same problem with my AE82. Has the timing belt been replaced lately ?. What about the timing belt tensioner ?. Some folks replace just the timing belt at the regular intervals and neglect the tensioner. The tensioner goes weak allowing some slack in the timing belt. I had the tensioner replaced in my 4A-C and problem solved. No more pinging. As far as i know nothing has been replaced lately, but i will look into the tensioner and belt. Thanks man And to solve the problem with the front CV, a mate of mine was buying a new car and just gave me his old 1985 rolla sedan so i just stole the whole hub and CV from it and put it in mine. everything running smooth now. Thanks everyone :wink: Rolla club #1! Report
November 26, 200916 yr comment_393721 About your Pinging...Had same problem with my AE82. Has the timing belt been replaced lately ?. What about the timing belt tensioner ?. Some folks replace just the timing belt at the regular intervals and neglect the tensioner. The tensioner goes weak allowing some slack in the timing belt. I had the tensioner replaced in my 4A-C and problem solved. No more pinging. Can also be from a carbon buildup on the pistons, around the valves. The carbon crap heats up and starts pre-igniting the air-fuel and you only really notice it when you start pushing the motor Report
November 30, 200916 yr comment_394571 Can also be from a carbon buildup on the pistons, around the valves. The carbon crap heats up and starts pre-igniting the air-fuel and you only really notice it when you start pushing the motor You are correct. In my case it was the opposite. Straping it out was fine. But driving around normal was the problem. So I tried not too as much as possible. Report
March 20, 201016 yr comment_423170 This might be a little late to say now but with the squeak/rubbing noise.. My ae82 did it too after the conversion. It was really bad at low speeds and i found it was the flimsy metal backing plate that protects the disk rotors. It was bent in a little and rubbing a bit so just with my hand i bent it back out, problem solved :) Report
