guys, i really need some fu*k*ng help! i took of the two badges (Toyota) and (Corolla) and now they have left these glue marks.
i have tried so much to get them off!
i've been scrubbing at them for ages.... i tried metho, goo remover, grease remover... i even tried with car wax.
either way, I'm screwed cos these stubborn marks aren't coming out. any suggestions would be greatly appreciated.!
Cheerz
As a last resort, try acetone in SMALL amounts. Although by the looks of things, the glue has reacted with the paint over the years and stained it permanently...
Citrus based products will remove it if its pliable.
thanks guys, i reckon i might need to try the 2500 grit or finer sandpaper... but it does seem to have baked into the paint :D
i don't think petrol is worth a try because metho would have been the same? and acetone.. wont that like burn stright through the paint?
gee, you guys really need to go learn some engrish :D
pliable = soft
ahaha, well obviously it is not soft or should i say "pliable".. if i have tried all these things...
there is is special rubber wheel u mount to a drill that will buff that of in seconds cost bout 15bucks from automitive paint supplier
Edited by greendog
