Ke70 Electrical Issues
They have common problems in the indicator stalk. There is factory bend in the wiring that will end up shorting out, not sure if that's your problem but worth looking at.
Rollaclub 1/4 Mile And Track Times Discussion
so i took my car wsid yesterday it was my first time ever drag racing,i had a ball,i had to take easy on the car as its my daily and i only been running for 3 or 4 weeks after completing a low budget 4age conversion. my target was to do a 15.9 ended up with a best of 15.50:) i know it will go quicker after a few tweaks. ae71 (full interior) ae82 big port (unknown kms bit smokey and used.) standard cams ,4k electronic dizzy twin 40mm dellortos stock 4ac clutch and how do make the pic a thumbnail or smaller?
Weber Settings
nice work! spewing my computers not able read pdf atm :(
4Age Injected To Twin Weber Carbs
runs good doug for early stages,bogging a bit like mine did,bigports makes it hard to tune that out.
don't know how to embed the video heres a link short vid at idle. http://www.youtube.com/watch?v=m8HSl9Rfz3k&list=UUceULHR-G-163RVx7gns9sw&index=1&feature=plcp basic rundown: standard bluetop unknown kms 2 40mm dellorto dhla f 32mm chokes malpassi fpr redline manifold trd? 4-2-1 extractors modified electronic 4k dizzy ae92 12v coil sv21 ignition leads
got my engine running now doughboy cheers for the dizzy works sweet.actaully goes alot harder than i was expecting.il post a pic of my setup up if u want.
Car Wont Start,with No Instrument Cluster?wiring Nerds Help Plz
yeah i have no idea how to hot wire a car unfortunetly , googling more on how now..ta
i just tried to start my ke35 i wrecked,it wont crank,its making relay noises at the relay under the dash. ive removed the instrument cluster,and it started fine before i removed it. does it need to be mounted to start? i really didnt think it would have been necessary for it start. if it is can i bridge the plug to start it.doing my head in here
Best Basic Cheap Mag Wheels
if you want something fat & lightweight,i can get 3 piece rims custom made to any size for around 1200,aus/US made.
The Dirty Datto 1600
quality 510 mate,ha don't throw the L16 out. the fastest 510 on the track at the last datnats was l18 powered:]
Ae71 Mods
mikey_m you want to sell me your motor?seriously keen. was this out of the jesus rally car?you have a pm
Will A Ke35 Steering Wheel Fit On Ae71?
hey people i need to get a roadworthy tomoz,so need a to get a horn going. i was going to just take a stock wheel off my ke35 and fit it to my ae71. I'm thinking it will fit,but its pissing down outside and can't be bothered to go try in the rain. can anyone shed some light? i did found a thread saying all kes use the same boss. cheers nick
Stock Compression?
ha inlet is like .10 cold think i found the problem
Stock Compression?
just been having some dramas with our rolla, maybe someone has some input for me...number 1 cylinder isnt firing all the time, weird but seems ok when cold.lead seems good, plug is nice colour not wet and fouled,which is what i was expecting. everything seems kinda ok.so just did a compression test on no 1 its telling me 150, pretty good to me ? so now I'm going to check my clearences, but could this be bent rod maybe or would i be able to hear that. will thicker oil bump the compression up a little, oil is old.
Datsun B210 Coupe Nsw
well I'm just about to get my 1200 ute back on the road so I'm selling my y as i don't really need anymore. I'm the 3rd owner, was owned by an old lady for about 25 years and was garaged at that time.. NO REGO! original a12 with 4speed not sure exact kms 110000 or 210000. reset rear springs cut front 310 control arm and ball joints carby was rebuilt bout 18 months ago drives exeptional new sony unit with 4 4inch speakers last owner tinted the windows looks only a few years old front unis are noisy(have spare but not any better really) minor damage in the rear rear gaurds have been cut, front rolled and have holes from fender mirrors minor rust car is pretty low and rides a bit harsh just the way i like it drivers seat has tears rest are pretty overrated will come with stardard steering wheel WHEELS PICTURED NOT INCLUDED $1900 car is located in wollongong 0401937684
