December 1, 200916 yr comment_394841 guys, i really need some fu*k*ng help! i took of the two badges (Toyota) and (Corolla) and now they have left these glue marks. i have tried so much to get them off! i've been scrubbing at them for ages.... i tried metho, goo remover, grease remover... i even tried with car wax. either way, I'm screwed cos these stubborn marks aren't coming out. any suggestions would be greatly appreciated.! Cheerz Report
December 1, 200916 yr comment_394843 As a last resort, try acetone in SMALL amounts. Although by the looks of things, the glue has reacted with the paint over the years and stained it permanently... Report
December 1, 200916 yr comment_394846 if all else fails, get some 2500 grit or finer sandpaper, then polish.... thats if it hasnt actually stained the paint as said above Report
December 1, 200916 yr Author comment_394854 Citrus based products will remove it if its pliable. thanks guys, i reckon i might need to try the 2500 grit or finer sandpaper... but it does seem to have baked into the paint :D i don't think petrol is worth a try because metho would have been the same? and acetone.. wont that like burn stright through the paint? Report
December 1, 200916 yr Author comment_394857 Citrus based products will remove it if its pliable. pliable? whats that mean? Report
December 1, 200916 yr Author comment_394859 if the glue has stained the paint permanently.. is there anything i can actually do? Report
December 1, 200916 yr comment_394860 gee, you guys really need to go learn some engrish :D pliable = soft Report
December 1, 200916 yr Author comment_394861 gee, you guys really need to go learn some engrish :D pliable = soft ahaha, well obviously it is not soft or should i say "pliable".. if i have tried all these things... Report
December 1, 200916 yr comment_394862 Methylated spirits is essentially ethanol, petrols completely different. Unless you mean mineral turpentine which is just more refined petrol. Report
December 1, 200916 yr comment_394913 there is is special rubber wheel u mount to a drill that will buff that of in seconds cost bout 15bucks from automitive paint supplier Edited December 1, 200916 yr by greendog Report
December 1, 200916 yr Author comment_394919 thanks for all your help guys :D i will let u know the results. Report
December 2, 200916 yr comment_394931 Eucalyptus oil....get most gluey stuff off. Great for rego lables too! Report
