July 3, 200521 yr comment_55118 I have an AE82 its stock bar the spottie on it the issue i have is that its hard to start and i wanted to find out why i plave another battery out of my rover (Mower) in it its a fair size its still 12 volt though and it started it the other day but i went to start it yesterday and it wouldn't start it turned over once and then stopped. The lights on the dash the oil etc went out and wouldn't come back on so i put the old battery back into it just wondering if anyone has any idea on what was/is wrong with the little beast. By the way in the way of spotties there is aprox 450 -500 watts of lights on the front. Sorry bout the long post. Report
July 3, 200521 yr comment_55121 sounds like a loose earth somewhere how many CCA is a mower battery? i wouldn't expect it'd be much, not enough to start a car anyway Report
July 3, 200521 yr comment_55136 I had a similar problem last week. I just replaced the battery clamps and cleaned up the battery terminals while i was at it. Make sure you fluid levels in your battery arent low either. Like Jamie said, check your earth straps too. Report
July 3, 200521 yr comment_55149 oh, that should start a corolla no worries. not the battery that's the problem then, unless they're both stuffed. try the corolla battery in the mower to be sure Report
July 3, 200521 yr Author comment_55154 Battery proves to be fine is starts my falcon ok thats what it came out of. Report
July 3, 200521 yr comment_55172 Maybe your starter is the culprit (had a lot of starter problems before, jamie knows this). check all leads that go to the starter, something might have come loose. Report
July 3, 200521 yr comment_55173 Tried talking to it.. "start god dammit, or ill buy a datsun" :P Report
July 3, 200521 yr comment_55179 Tried talking to it.. "start god dammit, or ill buy a datsun" :y: :P :D Report
July 3, 200521 yr Author comment_55190 Will check those things its more than likely sulking for I used to use it for everything includeing pulling my 1.2ton empty trailer then i would load it and now using the falcon its more than likely upset will tell it i will drive the falcon at all times if it aint careful :P Report
July 3, 200521 yr comment_55273 Talking to cars DOES work. I was trying to start Lola once, and she was refusing. So I gave her a bit of a peptalk ("Come on Lola, you can do it." etc). Yes, you guessed it, she started. Then my attention was drawn away so I stopped talking to her and she cut out again. Definitive proof that being nice to your ride can work. I told this story to someone else in front of my fiancee today and she asked why I never speak like that to her. I replied that I would next time she wouldn't 'start' at the right time. :P Report
July 3, 200521 yr comment_55315 One step up from talking to your car is talking with a piece of chalk. Tell it if it don't start your gonna draw a cross in the middle of the front bumper and then proceed to kick it with your steel cap boots........works with my "nuttin but twubble" only had to kick it once lol. :P starts every time the chalk comes out now. Report
July 4, 200521 yr comment_55657 I could never be that cruel to my car. Nah, I probably could be, but I'd have to be REALLY pissed off about something she's done. Report
