Hey guys just put new turbo on my 180sx but have good old one which is a T25G turbo, a mate said he can make manifold and I was just gonna plumb it all up but someone said I should ue what they call a suckhrough system? can someone explain or is there a "how to" somewhere?
as far as I'm aware t25 is a dynamicialy sealed turbo so no good for suck-through, you need one with a carbon seal
Correct, I should have thought of that.
However, I have noticed these seal kist on egay....
http://cgi.ebay.com.au/Garrett-TB02-T2-T25...=item3efc156a4e
The cost of the rebuild labour would probably not be worth it for a T25G though.
Just look into blow-through instead, then you can also run a cooler and fully hektik BOV.
Step 1) take engine
Step 2) bolt on turbo
Step 3) do mad skids...
Easy!
Its only 1 bolt to. Use a high tensile chrome bolt for a +25rwkw gain.
