andrushenko Posted February 15, 2010 Report Share Posted February 15, 2010 found a sweet auto ke70 with 80,xxxk, wondering how much a conversion to manual would be if anyone here wanted to do it for cash? Quote Link to comment Share on other sites More sharing options...
springersrolla Posted February 15, 2010 Report Share Posted February 15, 2010 a location would help Quote Link to comment Share on other sites More sharing options...
LukeAE71 Posted February 15, 2010 Report Share Posted February 15, 2010 If the car is as good as the k's suggest then just buy it, ask questions later. There would be a handful of KE's like that left in Adelaide. I would do it for you but you lowballed me on my Laser so you would most likely lowball my quote for work :) Parts for the conversion will probably set you back about $200 - $300 depending on where you get them from. The work would be like $500 or more if you paid a mechanic. Personally I would charge about $300 for this kind of thing because I consider my time to be valuable. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted February 16, 2010 Report Share Posted February 16, 2010 Its not hard to do yourself, but it is time-consuming. I don't think a mechanic would get it done in a day, the pedalbox is a killer. You need to get the driveshaft end altered, and the best thing to do is have a whole manual Corolla to grab bits off, rather than trying to buy bits piece by piece. Get a 5speed, not a 4spd. The diff has a lower gearing in the auto (4.3 instead of 4.1 I think) but the 5speed runs nicely on that. The 4speed revs its ring off. Here is how to do it- http://www.ke70.com/forum/index.php?showtopic=1493 Quote Link to comment Share on other sites More sharing options...
andrushenko Posted February 16, 2010 Author Report Share Posted February 16, 2010 If the car is as good as the k's suggest then just buy it, ask questions later. There would be a handful of KE's like that left in Adelaide. I would do it for you but you lowballed me on my Laser so you would most likely lowball my quote for work :) Parts for the conversion will probably set you back about $200 - $300 depending on where you get them from. The work would be like $500 or more if you paid a mechanic. Personally I would charge about $300 for this kind of thing because I consider my time to be valuable. haha don't have a cry :P I'm located in adelaide. so you reckon around 500 bucks would get me manual? including labour if i sourced my own parts and looked for private work? Quote Link to comment Share on other sites More sharing options...
LukeAE71 Posted February 16, 2010 Report Share Posted February 16, 2010 $500 would be the labour on it's own PLUS the parts :) Quote Link to comment Share on other sites More sharing options...
Grand Master of Awesome Posted February 16, 2010 Report Share Posted February 16, 2010 Luke will do the labour for you for $500 :) Quote Link to comment Share on other sites More sharing options...
Toy-Yoda[RL] Posted February 17, 2010 Report Share Posted February 17, 2010 $320 for a manual KE70 with a rusted out body, swap everything over yourself, easy. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted February 17, 2010 Report Share Posted February 17, 2010 Yes, buy a manual wreck because you'll need the flywheel and clutch as well- If you buy a gearbox that's probably all you'll get, and you will need all sorts of little things off the manual car. I assume you want to end up with a car that looks like it was made with a manual, not some half-done conversion with no gearbox boot. We paid $450 for the manual car and sold it after taking out the manual bits for $200. It is now undergoing some minor modification here on Rollaclub... You can do the work yourself, its much easier than tackling motor work as there is no complicated tuning involved. Just unbolt stuff off one car and bolt it onto the other. Quote Link to comment Share on other sites More sharing options...
Falken_KE30 Posted February 17, 2010 Report Share Posted February 17, 2010 $583.12 Give or take $400 depending on some stuff. But as others have said, buy a manual wreck, swap out whats better, swap the manual gear, do skidds... easy. Quote Link to comment Share on other sites More sharing options...
