Tally Posted July 8, 2010 Author Report Share Posted July 8, 2010 (edited) Thanks Parrot! its getting there, got flywheel, clutch, gearbox and tail shaft in. New roof lining in halfway as well. Interior is back in as well... Edited July 8, 2010 by Tally Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted July 8, 2010 Report Share Posted July 8, 2010 Lookin good Tally. can't wait. Quote Link to comment Share on other sites More sharing options...
JJT036 Posted July 9, 2010 Report Share Posted July 9, 2010 Lookin good Tally. can't wait. +1 :P Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted July 9, 2010 Report Share Posted July 9, 2010 Wow this thing is damn sexy! Can't wait to see it finished. Quote Link to comment Share on other sites More sharing options...
Tally Posted July 27, 2010 Author Report Share Posted July 27, 2010 (edited) Ok just to prove this project hasn't gone under ive got the front and rear windscreens in (although rear isn't in in the pic). Have started work on the engine. New water-pump and thermostat housing fitted. Now ive started work on the battery relocation to the rear. Ive got 4 meters of 2 B&S 32mm 255amp cable. Thing is though not sure what I'm going to do with some of these wires hanging off the side of the cable. Was thinking of some sort of terminal block or junction box to just save me the hassle and merge the existing cables together instead of removing old positive cable... And also as the engine is from a KE70 the Bosch alternator has an internal regulator instead of an external one that the car had originally... so not sure what to do with that. Edited July 27, 2010 by Tally Quote Link to comment Share on other sites More sharing options...
greenmac80 Posted July 28, 2010 Report Share Posted July 28, 2010 i can help you with the alternator thingo.. i recently did this on my 30. pm me. Quote Link to comment Share on other sites More sharing options...
son of stig Posted July 29, 2010 Report Share Posted July 29, 2010 In regards to the alternator problem, have a read of this KE55 alternator into KE20 Quote Link to comment Share on other sites More sharing options...
Tally Posted July 30, 2010 Author Report Share Posted July 30, 2010 (edited) ok so wont start, not getting any power... here is the deal... have wired engine up like following: standard liquid cell battery in boot 2 B&S 32mm 255amp cable for both positive and negative battery leads... positive straight to starter motor and negative to earth Wire from B+ on alternator to starter motor wire from D on alternator to i think white/black on old alternator connector on loom joined yellow/white and white/green on regulator loom... these cars are so small to work on from underneath, especially when laying on the ground... need a hoist lol will get pics in the morning, hopefully get it sorted with a fresh mind.... Edited July 30, 2010 by Tally Quote Link to comment Share on other sites More sharing options...
greenmac80 Posted July 31, 2010 Report Share Posted July 31, 2010 you need to remove the old regulator altogether and join wires. Quote Link to comment Share on other sites More sharing options...
Tally Posted July 31, 2010 Author Report Share Posted July 31, 2010 Yea nah I've removed it, problem sorted anyway, bad earth lol, always the case isn't it! Just have to sort out a few minor issues... Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted July 31, 2010 Report Share Posted July 31, 2010 Where did you earth the battery? A few people have had issuse when they earth it in the boot. Quote Link to comment Share on other sites More sharing options...
Tally Posted July 31, 2010 Author Report Share Posted July 31, 2010 Inside passenger rear quarter there was a good solid point. Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted July 31, 2010 Report Share Posted July 31, 2010 Ahhk, i know of a few people that have done it and reckon not to trust 40yr old steel as a good conductor. Last time i did a battery in boot conversion, i just ran both cables into the engine bay. But as long as it works for you :lolcry: Quote Link to comment Share on other sites More sharing options...
greenmac80 Posted July 31, 2010 Report Share Posted July 31, 2010 i did the battery boot bit and earthed the battery to the same point as the fuel tank was worked perfect. Quote Link to comment Share on other sites More sharing options...
Tally Posted August 2, 2010 Author Report Share Posted August 2, 2010 Just missed out on a brand new KE25 grill and corner garnishes for this, so pissed off lol ah well, were good price too... Quote Link to comment Share on other sites More sharing options...
