ok so been busy lately connecting engine bay up.
Did battery in boot conversion, solved my alternator woes, connected up all wires in engine bay, routed hearer hoses etc etc etc
So chucked battery in and away we went trying to start it.
Didn't start...
leads seem to be correct, aligned dizzy with 1# TDC so not sure whats going on, still might not be right?
stuff coming out the carby indicates leads wrong way around? Ive put them 1-3-4-2 just like the book says...
inside of carby is covered in what seems to be black oil/water not sure...
Check this video to see what I mean:
Edited by Tally
  • Replies 268
Didn't start...
yeah mate sounds like ur timing is wrong like it is 180 degrees out or something
have ya checked ur rotor button to make sure it is pointing towards cylinder 1 it should be in the manual or something????
see ya
jimi
thanks guys yea, turns out I didn't have it in right, was firing on the intake stroke.
Have since fixed it but yet to start it as battery is dead -_-
Didn't I tell you guys i chucked a v8 in the Corolla? ;)
yep got it started! I'm happy, gives you that peace of mind know what I mean.
Couple of pics of the car at the moment
and a pic of my new exhaust lol nothing special just 1.75" all way through
Front end is looking like this, waiting to replace front hub bearings.
Tried to see if KE25 4X110 hubs would fit AE86 strut stub axle, very very close to fitting but few mm difference in rotor bolt pattern, hub length and bearing size...
Edited by Tally
hey tally lookin great so are you using the ae86 struts on standard 25 lower arms if so do they bolt straight up or do you have to modify them at all
cheers graeme
Using AE86 powersteering arms with a balljoint adapter from techno toy tuning so it fits snug over the stock KE25 balljoint.
KE25 have narrower strut bolt spacing, used KE25 top hat and ae86 struts bolt in.
Hey Tally. I have some AE86 grease caps on order from Japan at the moment. Was only one in Australia and I needed 4.
$7.60 each trade, $9.17 retail.
Cap Front 43514-20010
I saw you were looking for them 'elsewhere'.
I tried getting some for the KE15 too. No go. might need to measure them up and look at generic repco ones.
How much longer till she hits the road do you reckon?
Main stuff
need to put rear window in which is proving to be a pain
get exhaust welded up with flange to manifold
and just a few minor things....
car still hasn't been rubbed back and buffed....
Got rear window in earlier today, wasn't easy I can tell you that.
It's getting kicked out the shed in the morning so will get it rolling and take a few new pictures...
