ae86
Motor 4agze
computer and accesories are map and cas
guys i need help with what alternator this is from
i have been to several wreckers and they are unable to id it, unfortanatly the toyota numbers are no longer readable.
the main things that are different are it mounts on the exhaust side, and the mounting is 68mm (every other alternator i have measured is 58mm). it also mounts very low right next to the sway bar because i have air con and power steering.
I'm 100% it is not a aw11 gze alternator because i have one of them and the plug is different and smaller mounting bracket.
Denso make hundreds of alternators that look similar, go to your local auto electrician and they should be able to cross refrence it with the mesurements and bolt and plug position with their catalogues.
