Izak Posted April 13, 2010 Report Share Posted April 13, 2010 hey was working on my 1986 Toyota corolla AE82 CS sedan and my boot all of a sudden wont close the coil in the boot or sumthing the previous owner said has problems but i dnt have a clue how to fix it and i need it fixed asap please if anyone knows how to fix it please help me!!! Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 13, 2010 Report Share Posted April 13, 2010 WD40 the latch, and pull the release a few times. Prob just stuck open. Or do you mean its stuck up and you can't lower it? Quote Link to comment Share on other sites More sharing options...
Old fella Posted April 13, 2010 Report Share Posted April 13, 2010 Angle grind a hole thru it and get a bit of chain and a padlock. BAHAHAHA!!!!!!! :( :wink: Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 13, 2010 Report Share Posted April 13, 2010 Quote Link to comment Share on other sites More sharing options...
Trev Posted April 13, 2010 Report Share Posted April 13, 2010 hey was working on my 1986 Toyota corolla AE82 CS sedan and my boot all of a sudden wont close the coil in the boot or sumthing the previous owner said has problems but i dnt have a clue how to fix it and i need it fixed asap please if anyone knows how to fix it please help me!!! Put the key in and turn it to the unlock position, If that does not work PM me your details and I will come look. Quote Link to comment Share on other sites More sharing options...
drc_ke20 Posted April 13, 2010 Report Share Posted April 13, 2010 (edited) maybe your cable is stuck or loosen up the latch? what about this one? Edited April 13, 2010 by drc_ke20 Quote Link to comment Share on other sites More sharing options...
parrot Posted April 13, 2010 Report Share Posted April 13, 2010 What you need to do is get inside with a torch and have someone slam it really hard. Make sure you have the key in your pocket so you can unlock it and let yourself out. Quote Link to comment Share on other sites More sharing options...
Izak Posted April 13, 2010 Author Report Share Posted April 13, 2010 ahah thanks for the funny pics no its open and wont close i neeed it to close Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 13, 2010 Report Share Posted April 13, 2010 It'll be the latch. WD-40 it. Quote Link to comment Share on other sites More sharing options...
Izak Posted April 13, 2010 Author Report Share Posted April 13, 2010 heres sum pics as you can see it wont close and its sumthing to do with the corners of it Quote Link to comment Share on other sites More sharing options...
Izak Posted April 14, 2010 Author Report Share Posted April 14, 2010 soo can anyone help me??? please Quote Link to comment Share on other sites More sharing options...
RainWarriorDregs Posted April 14, 2010 Report Share Posted April 14, 2010 i don't quite understand? whats fouling on what? Quote Link to comment Share on other sites More sharing options...
Old fella Posted April 14, 2010 Report Share Posted April 14, 2010 heres sum pics as you can see it wont close and its sumthing to do with the corners of it G`day mate, its hard to tell from the pics but its worth checking that the latch isn`t actually in the locked position when the boot is open. When you look at the latch it should have a gap that fits over the locking bar on the beaver panel bit. If that gap is not visible, grab a screwdriver/ pliers whatever and simply return it to the open position. Might take a bit of muscle coz its spring loaded. Cheers. Quote Link to comment Share on other sites More sharing options...
Trev Posted April 14, 2010 Report Share Posted April 14, 2010 G`day mate, its hard to tell from the pics but its worth checking that the latch isn`t actually in the locked position when the boot is open. When you look at the latch it should have a gap that fits over the locking bar on the beaver panel bit. If that gap is not visible, grab a screwdriver/ pliers whatever and simply return it to the open position. Might take a bit of muscle coz its spring loaded.Cheers. Put the key in and turn it to the unlock position, If that does not work PM me your details and I will come look. Tried to say that but he thought I was talking about opening it. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted April 14, 2010 Report Share Posted April 14, 2010 Does the boot go down to the closed position? or is it jammed up like that on the hinges?? Quote Link to comment Share on other sites More sharing options...
