Quickest K Powered Car?
LXY-642
I have got a plan.
I have had an idea for a long time! :ninja:
My project isn't as it seems.
I have only recently found this topic and think its a really good thing!
I have to cut down my project if only one source of charging is available.
Edited by Handiman
Link to comment
Share on other sites
The trimatics the box to use, plenty of interchangeable parts between all models. They will handle more power than any k will make.
And 12psi is for pussies! :P mind you I will only run about that, if I was going turbo I would run far more. Like I said, stu (kickn5k) will be running in the region of 30psi... Or as much as he can get in before it starts making to much heat. Split bores anyone? :D
The van box sounds promising, is it an overdrive box? Let us know what you find Cam.
JP
trimatic out of the older rollas is definitly the go, i still have one sitting here that i was going to use,
but never got around to it, surely the parts from other trimatics can be used, v8 clutch packs etc, like the gemini
trimatics, they can build that are in the 8 sec gems.
I never got around to looking at it, but if you want a auto, that would make more sense than a toyoglide,
especially in a tiny cube motor
cheers
darren
Link to comment
