Twinky's Old Fart [Now Super Dooper Charged]
I do have a blanking plate but that is not the issue. What you can't see is that where the blanking plate bolts on there is a big section of metal missing. That is why there is soo much silicon.
  • Replies 112
  • Views 69.4k
  • I HAAAVVVEEE SSPPPAAAAAAAAAAAARRRKKKKK!!!! YES! f@$kern finally.... It still won't start though..... I've double checked that the timing isn't 180 out so that part is good. Sounds like the timing is
Well it wasn't the dam points that are the issue. One of two things methinks.
1. Intake manifold leak
2. Carby not correctly functioning
Both of which are pains in the arse to sort out.
I am tempted to but I need to figure this out in case it's a problem with the head and not the manifold/carby.
spray carby cleaner around the manifold and see if ur idel picks up.
Drilled out the mounting plate to accommodate some sort of port on the bottom of the carb.
Not sure if it had any noticeable effect. I was a bit apprehensive about spraying a flammable
liquid all around my carb considering there was a hot exhaust right underneath so I sprayed water all around the carb.
I've sprayed water around before to track down leaks and it works a treat. at this stage I think that the vacuum leak is
coming from the manifold and not around the carby.
Machine the rest of the block down to the same level?
