June 3, 201016 yr comment_442193 as above who in adelaide does speedo calibrations? i have an aftermarket spec speedo and an electronic speed sender from a newer toyota that fits into the t50 i have, need to calibrate it.. however if i can figure out how many revs per km the car does i can do it myself as the sender is 4 pulses per rev. but i'm a maths dumb ass. thanks, Luc Report
June 3, 201016 yr comment_442198 I've heard guage works could help you with that, or you could get a speedo corrector from jaycar for about 55 bucks, just needs assembly Report
June 3, 201016 yr Author comment_442213 nevermind i figured it out. my tyre spins 551 times per km the diff ratio is 4.11 and the sensor pulses 4 times per rev so 551x4.11x4 = 9058.44 pulses per km. sweet as bru. Report
June 3, 201016 yr comment_442262 to check how accurate it is. use a gps as they tell u how fast you are going and most gps's are more accurate than new car speedos Report
June 10, 201016 yr comment_443815 to check how accurate it is. use a gps as they tell u how fast you are going and most gps's are more accurate than new car speedos A GPS also only updates once per second, so its more a guide as its not THAT accurate. :) Report
June 10, 201016 yr comment_443871 Somewhere around must be a measured Km or two on a motorway or major road. They have odo-checking markers for the public and often road engineer's markers on bridges and posts. Just run along that at a constant speed with a stopwatch, its what we did before every set-speed rally. High-school physics... spd=dist/time. Time for a km in seconds =3600/speed So its 30seconds for a km at 120kph 36seconds for a km at 100kph 40seconds for a km at 90kph etc Report
June 10, 201016 yr comment_443883 how I've done it. Mark out 1 km exactly. yeah thats the tricky bit. Set the trip meter to 0. Drive the 1km. See what the trip meter reads. Use the + - percentage to work out the inaccuracy. I know analogue gauges can be tricky, but a very good indicator. Report
