September 4, 201016 yr comment_465650 Has anyone fitted discs to a hilux diff??? yes you can i haven't done it yet but will be on my RN25 diff using MA70 rear hub carriers, backing plates these should be compatible and of course the brakes you will have to upgrade your master cylinder and also you can use a supra LSD too but what model diff may vary which supra and brakes you use the RN41 diff you can use disc brakes add in a G series LSD centre and MA70 rear hub carriers, backing plates and brakes hopefully this helped Report
September 4, 201016 yr comment_465681 Has anyone fitted discs to a hilud diff??? Yes you sure can. If you get in contact with a member that goes by the name of "Curly" he may be able to supply a complete kit (there are 2 different sizes, I got the 300mm disc kit). all the best Report
September 5, 201016 yr comment_466064 prices mate ? Just brackets $60 or recoed R31 skyline calipers, new pads, new 300mm dba discs, all hoses, bolts, clips, brackets, everything you need to bolt and go $600, add $200 for new handbrake cables but you could possibly make up yourself, you need 15in wheels for these but i can do a 4 x 114 with 260mm discs for about the same, these will take 14in wheels Report
September 6, 201016 yr comment_466350 sorry to hijack ya thread V6CHVROLLA but just to save a new thread and mods or others complain Q for Curly, does that brake kit fit a RN25? maybe keen on a kit later on down the track if ya still doing them Report
September 8, 201016 yr comment_466911 hey curly i sent you a pm about possibly getting one of these kits and some other stuff about a week ago, did it not go through? very keen, please pm me back sometime :D Report
September 8, 201016 yr comment_466963 hey curly i sent you a pm about possibly getting one of these kits and some other stuff about a week ago, did it not go through? very keen, please pm me back sometime :D PM,d I think they fit all hilux diffs Report
September 9, 201016 yr comment_467016 How much does the hub protrude the disc on these curly? Ive seen a couple that sit almost flush which can be a good thing for the wheels as they have nothing to locate them on? can't quiet tell in the above pics. Edited September 9, 201016 yr by cuzzo Report
September 9, 201016 yr comment_467276 ive had my wheels made up to accept the offset of the drums ... if i had the disc's will the length /offset of the diff change or will it remain the same also can you do 300mm 5x114.3 pattern? Report
September 13, 201016 yr comment_468386 can you do 300mm 5x114.3 pattern? Yeah that's the kit I got of Curly Report
September 13, 201016 yr comment_468558 How much does the hub protrude the disc on these curly? Ive seen a couple that sit almost flush which can be a good thing for the wheels as they have nothing to locate them on? can't quiet tell in the above pics. The thickness of the disc is the same as an original brake drum so track and wheel fitup wont be affected, but with the 300mm discs you have to run 15in wheels Report
