Shit Box Ke70
f@$k yeah ryan, I'm quite keen man, you know if your prepared
to help dude ill make it worth your while. Might have to get a taxi
to my house and back that day lol. :rolls:
Taxi eh? i like your thinking Pete lol.
  • Replies 47
  • Views 15.6k
Another busy day with the Rolla, I'm really trying to make the most of this
next 2 weeks cause I'm holidays and usually this sorta shit would be done
on weekends.
Fully striped the car of its doors today which was really easy but i decided
that rather then throw them out complete it was probably smarter to strip
them of all theyre goodies first. I took absolutly everything including the rubbers,
saves me having to buy more if i need them for the next doors i buy, plus if
a window breaks or a lock f@$ks up i wont have to mess about trying to get
it from a wrecker.
Looks great mate, will be awesome in fresh white. Definately needs an outomotive oncologist though.
On the cut springs idea... Nobody except Dave has touched on whats really the worst part about cut springs. The spring is usually wound to a shape that flattens out at the end to give excellent contact and ability to stay in the spring seat. When you cut them, they usually just sit on one point, so then its a whole lot different the way it behaves and you have basically cut the slightly progressive rate part of the spring off. You now have reduced resistance to bottoming and also reduced contact with the diff. Now you have two things to be worried about. I will concede that my paddock car has had cut springs under it at a rather low height for some time, and we drove it hard enough to snap both shock absorbers off at the bottom bush cups and did a couple laps even bouncing through a gully at about 50klm/hr on just springs, and they never fell out, but thats not to say they wouldn't, I'm sure it would just take the right (or wrong?) bump and you'd be in trouble. More to the point is, if you do cause an injury or death, and believe me this does happen all too often, then you can't be insured and the person you hurt will get screwed by you declaring bankruptcy because you cannot pay if the insurer works it out. Plus it drives way better with the right springs in it, cutties are always bouncy. Youll survive rolling around the suburbs but don't go on the highway and expect to keep all your tyres inflated and your spine intact.
Ive sanded back the car now and have had a better look at the rust
between the boot and the left tail light and its pretty bad, i havnt
had much to do with body repairs at all and it looks like a pretty
awkward area to cut and weld a plate in, but then again mabye it isnt?
I just wanna cut as much as i can out and bog over it but what i wanna
know is how longs that gonna last before the rust comes back through?
If youve done this before od worse let me know how you did it,cheers :y:
On the fuel filler part i've got rust in mine but all i did, was fill that shit up and sand it flat with the body again and then paint over it aye, but the other bit along the boot i can't help you my 70 doesn't have that much rust in it at all
I think at the end of the day I'm probably gonna do the same thing.
around the boots a bit of a worry though.
I just bogged mine, its only meant to be temporary
Yours actually came up pretty good man, i did all the
body work today, i just used body filler though, tomorrow
ill try to sand it all back then prime the bad areas,
photos will be up when its done, not sure how PRO its
gonna be.....
Edited by KETURBO25
So today i finally got around to getting some primer and some
photos of the really bad rust spots which ive now fixed, its only ment
to be temporary, but I'm pretty happy with how it came out. Its my
first time trying to fix rust this bad, and too be honest repairing
it has been pretty f$#ked. Ive got a lot more respect for people
that have the skills and patience to restore cars properly now.
Edited by KETURBO25
patience is the key aye.
Sanding gets tedious but results speak for themselves
if you take your time.
Agreed, the hardest part for me was getting some alloy
mesh to stick behind the holes, and both the fuel tank
and the boot seal were hard to get behind, The boot seal
was even harder cause there was pretty much nothing left
of the metal to stick to, oh well its done and its a temp
fix but at least its good enough to paint over now.
Hard as nails. Serious. Smear a little bit of that shit on and it isnt coming off in a hurry.:no2:
I used it to patch a hole once and needed to angle grind it out.
But like in my pics I just duct taped over the hole and ran fibre glass bog from behind then plastic putty on the outside.
lots of ways to do it. Just gotta be creative. :laff:
Plenty happenin atm, recently bought a donor car for my auto
to manual conversion, Totally stripped it of its drive line
and front end, there was no interior in the car as it was set
up as a burnout car. I'm planning to get this thing road ready
before the end of the year, seems like a long time but ive still
got a lot to do.
So far the car is in primer and all the rust has been repaired,
the next step will be to get some paint on it and get the manual
up and running, shouldnt be too hard, just a matter of time really...
Whats left of the Donor...
Thought id freshen up the 4K a little...
Looks nice mate,
When did you get the donor car?
If you do little things every night you'll find that it gets done a lot quicker. Just need the motivation. :wink:
Do you have a check list of thing to do?
I got the donor car last week on wednesday and pulled it all apart
then got rid of it this morning, bought it off Gumtree for a good
price-it was regency defected.
As far as the checklist goes I'm not really planning to go too crazy
with it cause its not my main ride, its just a daily for me man,
the KE25 keeps me happy enough. Once its painted and its manual ill
be happy.
