Ke26 1Jz Turbo (No Longer 13B Turbo)
i got no idea why the charged more then they quoted...put it this way, the final bill is approx $2000 more then quoted... yeah they were saying it was just oil from the box, ill be majorly pissed if its a loose fitting or something fitting related, but if its from the bellhousing I'm going to check the pump.... as for the rubbing inside the bellhousing, I'm not sure what that could be, ill check that out when it all comes back...and no park, ill pull the shifter cable off the box and try and manually put it into park, if it doesnt go in ill be sending it back to the box rebuilder for answers and a repaired g/box
  • Replies 366
  • Views 495.7k
  • so went to che again to see some progress, fuel system setup has changed again, now gone back to the surge tank idea but moved the surge tank under the car.. Its a real nice setup and chris, the gun w
  • Yeah he is awsome...   Yeah its coming out the way i wanted it, its had its ups and downs, times when i was pumped to see it finished, other days where i wish i never had it....People tell me I'm wa
  • heres a pic of the near complete engine bay, full of things now...screamer pipe still hasnt been done yet. eagerly awaiting
f@$k. $2,000 more then they quoted. That's insane. Taking it elsewhere after the gearbox issue is sorted?
Hopefully it's an easy fix. And if not then hopefully the gearbox builder don't mess you around.
well I'm thinking about taking it elsewhere to get tuned, don't know yet.....there tuning side of things is really good..but i will be asking for a definate price before the car even gets there and a definate time frame for sure.. Yeah hopefully its an easy fix
went and had a look at the car today, man the motor sounds sweeeet as, but the gearbox does not.. the noise is pretty loud and the leak is pretty bad.. pick it up this week and will get this box done soon
Awesome man! :dance:
Pity about the other problems :(
Double post = overwhelmed with joy! :lolcry:
Edited by SLO-030
Thats sounds f@$king horrible! Good to hear it up and running. Even better when the issues are taken care of. :happy:
your a gamer man than me running it for that long with that noise belting out of it !!! sounds like its in the bellhousing cracked flex plate ????
yeah I'm not going to be running it any more until we actually go to fix it... yeah my bet is that its something to do with the flex plate hitting the bellhousing or something.. it don't idle right because it isnt tuned
Unless the original quote was $20,000 then that's ok. Did you get the quote written down?
Technically you can only move 10% from an original quote(from what I've been told) I'd tell um that's crap and that you'll be having a chat to the ACCC.
It's good to hear that it's running though.
Stu.
quote was verbal.. get it back tomorrow so ill check it all out then
got the car back today...will do the box when i can be bothered...che said they had tried all the things i said to fix the box so looks like its gonna come straight out and sent away
Keep at it mate,
I'm sure when she is running, you will have the biggest smile
