Strut Top Removal
I'm under the impression that normally you need a spring compressor to remove the strut tops, since there under load all the time. But do i still need one if i can adjust my coilovers so the spring is under NO tension?
Reason why is that the guy , when putting together these struts mismatched the hats, so the brakes face the other way. So i need to swap them over
Edited by Jason
if u can adjust it enough to make it not under tension thats the way to go. But most don't have that much adjustment.. it only cost like 15bucks for two spring clamps from autobahn..
Well i tried to get them off, and then the shock rotated with the bolt.... Is there some sort of tool i need?
yes, a rattle gun
sometimes you can bolt the top plate to a bench or something and get it off that way, but it's a pain in the ass
I was thinking about bolting except the thing ways about as much as the car (you can lift stock one with one hand, i struggle to lift new one with two) and wont fit on my bench :)
there seems to be a notch on the top of the shock, see if any of my spanners fit it
Edited by Jason
judging from the last pics of jason's shell, i have the feeling it's a bit late for that :) it is a good idea tho. some people will tell you this is a bad idea, and you'll punch the strut through the bonnet, but if you look at the design of the top seat, this is physically impossible
the last one i did with a socket, i clamped some locking pliers to the top, stood on the pliers, laid the strut on the ground, and undid it that way. it took ages
nowadays i just take them to my roadworthy guy who does it with rattle gun for 5 bucks
i'm not sure how useful a battery powered rattle gun would be, it depends how tight the nuts are done up. the ones on my ke25 were done up in a tyre shop last, so they would have had a huge compressor and a good rattle gun. it took a long time for the nut to loosen using a 2.5hp compressor and $80 rattle gun
notice i said loosen, not totally undo.
do the final tightening after the struts are back in and the car is on the ground.
there will always be a next time....
if the strut is out of the car, you can always use a socket, breaker bar, and big f@$king hammer to shock it loose. this works..... easier to initially loosen off before you remove the struts though.
hmmm, this calls for the extra extra large mofo bar (yes, we have an an extra extra large mofo bar, along with the extra large mofo bar, mofo bar and masssive mofo bar) :)
Edited by Teddy
trying to make that shell... not such a shell :pirate:
I WILL get these on tomorrow no matter what :)
if you're getting serious about building cars, a compressor and air tools is almost a must
