December 28, 201015 yr comment_491076 hi i am currently looking for an ae71 sedan to build as a slider, i have found a wagon for the right price but was wondering if it is the same as a sedan apart from the shell, so does it have the same 4ac? t50? driveshaft? diff mountings? let me know please cheers Report
December 28, 201015 yr comment_491085 you can slide leafs, just use anti-tramp rods and a pan-hard rod. Although putting a panhard in isn't that easy Report
December 28, 201015 yr Author comment_491116 mmm but its just going to be a learn to slider then move onto something bigger/powerful so the easier/quicker the better might just stick with getting a sedan then, Edited December 28, 201015 yr by rb1994 Report
January 2, 201115 yr Author comment_492173 a wagon has the 4ac and t50 though? so it would have same cross members? Report
January 2, 201115 yr comment_492177 4ac? t50? driveshaft? diff mountings? a wagon has the 4ac and t50 though? so it would have same cross members? 4ac? - yes t50? - yes driveshaft? - different diff mountings? - different Report
January 2, 201115 yr comment_492178 same engine/clutch/trans, both crossmembers but not the rear half of the tailshaft and diff Report
April 5, 201115 yr comment_514901 driveshaft? - different What's different about them? Is it just that the wagon shaft is one piece while the sedan is two? I ask because we are putting the sivertop, T50 and rear suspension from my old 86 into a KE70. We heard that to do that we would need the AE71 tailshaft to go from T50 to S series diff, but could keep the KE70 shaft if we were using the KE70 rear end. I've found someone locally with a one piece AE71 tailshaft from a wagan and was just wondering whether it would fit. Report
April 5, 201115 yr comment_514913 AE71 sedan for T50 to borgy And going by what Trev and Sam say AE71 wagon for T50 to S?? But presumably you can mix and match with both the 86 and 70 tailshafts depending which way you want to go. You wont be able to use the KE70 front half. Report
April 5, 201115 yr comment_514946 What's different about them? AE71 sedan for T50 to borgy And going by what Trev and Sam say AE71 wagon for T50 to S?? But presumably you can mix and match with both the 86 and 70 tailshafts depending which way you want to go. You wont be able to use the KE70 front half. S and borgy are different. Report
April 6, 201115 yr comment_515193 wagon tailshafts are longer than sedan ones anyway No. I had my van one in my sedan. Report
