jaygore Posted January 6, 2011 Author Report Share Posted January 6, 2011 BLZBUB666: I thought about doing that... But the parents are neat freaks and wont allow it :/ so that option is out... Hahaha the other idea was, the antenna on the roof is pretty much above my bedroom, so i could run another cable from it through my window hahaha! Dave: I have tried it on the outdoor antenna works a treat, I have had it in 3 houses now and has worked fine in every single house... Now that antenna would work lol... I'm thinking maybe I can jump up on the roof and see if i can somehow route another lead through my window, it could work Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 6, 2011 Report Share Posted January 6, 2011 If its close to your room do that. Nice and simple. There should be room on the antenna to run another cable too. Either that or get an exterior splitter box. Saves you buying a new one. Quote Link to comment Share on other sites More sharing options...
jaygore Posted January 6, 2011 Author Report Share Posted January 6, 2011 yea and they are cheap as chips from dickies! and maybe 20 meters of cable should keep me out of trouble haha Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 6, 2011 Report Share Posted January 6, 2011 Just get something to hold it to the roof so it doesn't rattle in the wind or you'll go crazy :zzzz: Quote Link to comment Share on other sites More sharing options...
jaygore Posted January 6, 2011 Author Report Share Posted January 6, 2011 oh hahaha yes thats the last thing anyone would want... Quote Link to comment Share on other sites More sharing options...
marksKE25 Posted January 6, 2011 Report Share Posted January 6, 2011 I instal TV Antennas in Perth WA. What you need and questions that ned to be asked. How far are you away from the transmitter (the tv stations one) The terrain between your house and the transmission. You have a tin roof so indoor antennas are going to be very limited same as putting one in the roof space. You need one on the roof. Every time you split the cable to a different outlet you lose about 4-5 db so if you have a 4 outlets in the house you need a 4 way splitter DO NOT USE MULTIPLE 2WAYS you will degrade the digital signal. At the antenna for a 4 way splitter you will need a signal strength of about 60db to do it without a booster. If less you will need a booster (signal amplifier)I recommend the kingray pole mounted ones. the Amp goes before the splitter as close to the antenna as you can get, once the signal degrades in the lines then it can't be brought back. use proper connections all the way along. With digital you get a perfect picture or nothing. if you have any question please don't hesitate to ask. Quote Link to comment Share on other sites More sharing options...
jaygore Posted January 6, 2011 Author Report Share Posted January 6, 2011 Cheers mate, that answers alot of my questions... Well I live in ballarat so the terrain really isnt that bad between me and the towers, so that shouldnt be an issue. What is the usualy average cost to get someone in to install another port properly in a room directly from the antennna on the roof??? Quote Link to comment Share on other sites More sharing options...
coln72 Posted January 6, 2011 Report Share Posted January 6, 2011 GRRR just notied our f*&^%# telly has dropped out again. Not happy Jan :( Worked fine this morning too..... Quote Link to comment Share on other sites More sharing options...
jaygore Posted January 6, 2011 Author Report Share Posted January 6, 2011 Bugger man... I would have thought maryborough would be fine... Maybe you guys need to upgrade the antenna :/ or it needs to be pointed in a different direction Quote Link to comment Share on other sites More sharing options...
jono1986 Posted January 6, 2011 Report Share Posted January 6, 2011 (edited) Can you con 75 bucks from somewhere cause that's all a antenna guy will charge you to get a plug in your room, that is the best bet unless of course you can get in the roof and install a proper aerial splitter and run cables yourself. Ummm cbf'd reading the latest replies before i wrote this but hearing the same info twice is always a good sign :happy: Edited January 6, 2011 by jono1986 Quote Link to comment Share on other sites More sharing options...
jaygore Posted January 6, 2011 Author Report Share Posted January 6, 2011 na no one has suggested that one yet jono, However I didnt realise it was that cheap to get an antenna guy in to do it, So I may as well go down that path... Quote Link to comment Share on other sites More sharing options...
swampgarage Posted January 17, 2011 Report Share Posted January 17, 2011 I used to have an ancient PYE tv in my room. It picked up all the channels with nothing more than a paperclip jammed in its antenna socket! The transmitters were 40km away, but there was a direct line of sight. I think it also had a nuclear powered tuner - it hissed like crazy and smelled funny. When I was at uni, we watched the olympics using a pair of scissors as an antenna - once again, just wedged into the back of the tv. In cairns I had to buy the biggest antenna I could get, then run a booster to get any picture at all. Quote Link to comment Share on other sites More sharing options...
