t18drifts Posted March 16, 2011 Report Posted March 16, 2011 ok so i need to change my tie end rods and I'm thinking that wheni replace them i might replace / upgrade stuff to do with my steering n shiz for better handling but i wont to keep the steering box not rack and pinion Quote
Jono.C Posted March 16, 2011 Report Posted March 16, 2011 Otomoto weld on coilover kit, Spring stiffness will depend on what you're using the car for, 6kg should be fine for the street Quote
t18drifts Posted March 16, 2011 Author Report Posted March 16, 2011 Otomoto weld on coilover kit, Spring stiffness will depend on what you're using the car for, 6kg should be fine for the street http://www.otomoto.com.au/HDSystems/sleevekits.htm dem ones Quote
Jono.C Posted March 16, 2011 Report Posted March 16, 2011 yeah, those ones, put them in a mates a ke70, they're great Quote
t18drifts Posted March 16, 2011 Author Report Posted March 16, 2011 u have to change the original shocks yeah but to what Quote
Grand Master of Awesome Posted March 16, 2011 Report Posted March 16, 2011 replace all your bushes. Quote
ke70dave Posted March 16, 2011 Report Posted March 16, 2011 replace all your bushes. and get some good tyres. Quote
t18drifts Posted March 17, 2011 Author Report Posted March 17, 2011 I'm not to sure how good they are it all seems pretty good its on some pretty stiff king springs when i got it the back end is a little softer then the front Quote
t18drifts Posted March 17, 2011 Author Report Posted March 17, 2011 There just stock shocks btw Quote
t18drifts Posted March 18, 2011 Author Report Posted March 18, 2011 Is there any ae86 or s13 parts that will fit in the front end suspension and steering Quote
mungi mods Posted March 18, 2011 Report Posted March 18, 2011 easiest way is new wheel and tyre package wider wheel with wider tyre = better handling ,as greater contact patch will increase stock grip then coilovers with 8kg spring and agx adjustable inserts 6kg rear springs with upgraded shocks new nolathane bushes through out. etc etc etc Quote
t18drifts Posted March 18, 2011 Author Report Posted March 18, 2011 yes i have ma61s in the shed they need new tyres though there to wide atm Quote
