rob83ke70 Posted April 25, 2011 Report Share Posted April 25, 2011 I've got a ke30 which is going to be primarily driven on gravel, it currently has the small front swaybar and no rear swaybar, and I have a ke55 which is being pulled apart for the good bits to go into the ke30, and it has the bigger front swaybar and it has a rear swaybar. Is it worth swapping swaybar setups from one to the other? Robert. Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted April 25, 2011 Report Share Posted April 25, 2011 Think u just answered your own question! :P Quote Link to comment Share on other sites More sharing options...
rob83ke70 Posted April 25, 2011 Author Report Share Posted April 25, 2011 so the bigger swaybar and rear swaybar will be an improvement for gravel handling? Quote Link to comment Share on other sites More sharing options...
coln72 Posted April 25, 2011 Report Share Posted April 25, 2011 I'd go the front, but leave the rear off. Quote Link to comment Share on other sites More sharing options...
tojo2 Posted April 25, 2011 Report Share Posted April 25, 2011 Id put in the thick frontbar (+new bushes) then try with and without the rear.. shouldnt take long I prefere the rear to be a fair bit softer than front on loose surfaces like snow & gravel Is your diff open ? Quote Link to comment Share on other sites More sharing options...
corollaart Posted April 25, 2011 Report Share Posted April 25, 2011 [quote name='coln72' I'd go the front, but leave the rear off I'm with colin,you don't want to pick wheel up on the gravel .Leave the back a bit soft. Quote Link to comment Share on other sites More sharing options...
rob83ke70 Posted April 26, 2011 Author Report Share Posted April 26, 2011 not sure about the diff yet, I'm considering either a phantom grip or maybe *maybe* welding it. when we were running the ke55 it had an open centre diff and both swaybars, and it did have some issues spinning one wheel. Never tried it without the rear swaybar in a khanacross :( Quote Link to comment Share on other sites More sharing options...
corollaart Posted April 26, 2011 Report Share Posted April 26, 2011 Rob get the welder out lock it up ,i can't think how bad it would be with a open diff yuk. Not to mention the times . rob Quote Link to comment Share on other sites More sharing options...
rob83ke70 Posted April 26, 2011 Author Report Share Posted April 26, 2011 when I decide on what diff ratio I want I'll probably weld a centre up. would the rear swaybar help or hinder it with a locked diff? Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted April 26, 2011 Report Share Posted April 26, 2011 Weldy will cause more under than over steer only gravel. Don't need it for sideways. Quote Link to comment Share on other sites More sharing options...
coln72 Posted April 26, 2011 Report Share Posted April 26, 2011 Ran a locker in my KE20 with and without a rear bar. Rear bar didnt last very long before it was removed. A bit unnerving using the drivers window to see while in third gear during an autocross. Ended up disconnecting one arm to try to tame it a bit, which did work. Ended up with softened springs - 2 leaves instead of 4. This helped lots in my case. Quote Link to comment Share on other sites More sharing options...
